"Dialed in" how?Well, it's been years since I experimented with it. But once it is dialed in, it doesn't sound spatially deficient as it is good at reasonably fooling one into thinking that it isn't.
We're not talking about stereo from 5 speakers. We are talking about discrete high resolution 5 channel sources.Stereo sound from 5 speakers equidistant won't give you a feeling of live music, which would never sound like that.
Not really. Only that they are of requistely high quality. (I know that is probably anathema to many here.)Doesn't that depend on what kind of speakers the 5ch are and what amps are driving them?
A friend of mine has superb Magico multichannel system and, definitely yes, it is better in multichannel than in stereo.What if it is 5 ch of Wilson or Magico? Is that better or worse than 2 ch of the same?
Ok, whatever - how much "recording space" is needed to enjoy a recording is not a question I lose sleep over. Getting the best out of music I like seems more rewarding than having to limit my listening based on (insignificant) recording criteria.They can be omnidirectional but, even when not, they cannot fail to capture aspects of the recorded space.
Ancient info. The B&Ws were replaced by Revels and, then, by KEFs. Yes, there is no processor, per se.Kal Rubinson is using B&W without processor I believe.
Fixing the typo. However, there are situations where the composer/performer explicitly intended for there to be voices and/or instruments elsewhere or off-stage and multichannel can do that thrillingly.That's not howMCH works - rear channels have ambient info, not same info as front channels.
No such processing is involved. We are (or, at least, I am) talking about discrete multichannel recordings in PCM or DSD which have not been processed or packaged into a CODEC and which are, in every way except channel count, identical to the PCM or DSD on a CD, SACD, BD or file.To clarify - by processing I meant something like Auro 3d/Atmos which processes more than the 5 channels. Even without a processor like those, a multichannnel preamp is required, but is taking 5 channel source into 5 channel pre into 5 amps, or a multichannel dac like exasound.
Nope. No disc player. BTW, what sort of "processing" do you think is necessary in a disc player?Ok, then there is still a processor in the multichannel DVD player...nevertheless there is always a processor...
I bet that had an incredibly immersing sense. And the scale is probably off the charts.Ancient info. The B&Ws were replaced by Revels and, then, by KEFs. Yes, there is no processor, per se.
To be specific, I am playing discrete multichannel files with resolutions up to 32/384 or DSD256. The playback software (Jriver) on my PC feeds a multichannel DAC which, in turn, feeds power amps and speakers.
@Bonzo,
Do you own lace up shoes?
Signal steering of course.Ancient info. The B&Ws were replaced by Revels and, then, by KEFs. Yes, there is no processor, per se.
Can you be more specific? The content has separate data for each channel.Signal steering of course.
Ok, all I can say is that the many multi channel demos I have heard didn’t feel more real…they in fact felt more artificial…
Over the years, the majority of all the audio systems that I have heard, regardless of cost or configuration, were disappointing. So what?Ok, all I can say is that the many multi channel demos I have heard didn’t feel more real…they in fact felt more artificial…
Don’t disagree, but I have yet to hear a truly convincing multi channel system and have heard at least some truly amazing two channel systems.Over the years, the majority of all the audio systems that I have heard, regardless of cost or configuration, were disappointing. So what?
Ok, none of them sounded very real.It would be great if you referred how real sounded the best multi channel systems you listened, not the poor ones.
The best I listened was an all Martin Logan system and it sounded extremely good - a great feeling of being in the concert hall. As far as I have seen, setting up a good multichannel system needs expertise - not just running some a auto set up ...![]()
So, are you saying the rear channels, which normally would be just room ambience, tracks recorded that way? How is that generated during the recording process? Is it really recorded with multiple microphones, or is this somehow synthesised from the original stereo recording?Can you be more specific? The content has separate data for each channel.
I can't parse this. Are you saying:So, are you saying the rear channels, which normally would be just room ambience, tracks recorded that way?
How is what generated during the recording process?How is that generated during the recording process?
Aha! Yes, it is really recorded with multiple microphones. The actual arrays are determined by the recording engineers and they may vary in how they choose to capture a particular performance in a particular space.Is it really recorded with multiple microphones, or is this somehow synthesised from the original stereo recording?
Agree on the multichannel setups …Don’t disagree, but I have yet to hear a truly convincing multi channel system and have heard at least some truly amazing two channel systems.
"Dialed in" how?
Yeah, well, it's a manipulated effect, imho. So, OK if you like it.The processor has adjustable filters and parameters.
