ordering lampizator GG
awsmone
1,617
517
1,185
Canberra Australia
Hi there
I need some advice ordering a Golden gate lampizator
there appear to be a few options
single ended or balanced
in SE you have a choice of tubes not balanced 101 D only
although my system is balanced the distributor recommends SE
this will give me more tube options
I mainly listened to classical with a little jazz
Is 101D the way to go
as most of my if not all cd and dsd is on computer should i ask for other options i don't you a server
thanks
Andrew
http://lampizator.eu/Fikus/TRUE_BALANCED_DSD_DAC.html
You can do more than 101d with Balanced:
All DHT DACs are now available as balanced: with 4 output triodes and 4 output caps.
That applies to the Golden Gate, The Big 7 and the Lite 7 .
The compatible tubes are: 101D and 45/245/345.
NO 2A3 or 300B are approved
You MUST have matched quads though, as it is FULLY internally balanced. You can do Psvane WE replica 101ds (standard in the GG) and you can get a quad of EML 45 - Mesh plate DHTs for a very different presentation. Also, not that the rectis can be rolled too and the combo of recti and DHT make a huge difference to the final sound. Thus you still have tons of permutations to play with in the Balanced. You only really lose 300b/2a3 and perhaps 6a3 rolling options. The expensive Elrog 300b is a favourite of the high rollers, but so are the EML anniversary 45 globes and the regular EML mesh plate 45 tube.
If the rest of your system is fully balanced (no faux-balance, but REALLY fully internally balanced) then the Balanced Dac is the better option. If any element is SE, then you are better off getting the SE Dac.
No other option obvious, unless you are a Headphone guy and would like Headphone out plugs up front. That would enable you to drive low to moderately demanding Phones, like Senn HD800. My stong advice though is to get an Uptone Audio Regen device. Back-ordered to July, but worth it. To step that up, you could replace the supplied quality SMPS with a quaility Linear PS of 7v to 12v and circa 1 amp current rating. Hynes SR3-12 would work fine for the GG.
Congrats on your imminent GG.
Thing is, you will never be able to get the original WE 101Ds in a matched pair of quads. That said, I love 101Ds for classical and if your entire system is balanced get the balanced - unless you willing to change you pre and power.
Hi Norman,
This is an excellent post. I was corresponding with Cyrill Hammer of Soulution and he told me that my Soulution 520 Preamp is unbalanced, even through the XLR connections. So based on what you're saying, it would be better to go with a single-ended GG/B7 in my system? If this is the case, what would you think about me requesting additional XLR outputs on the GG/B7? I prefer the XLR connection to the RCA. I believe the all aluminum chassis Big 7 in the photo had this setup.
Thanks,
Ken
Ken,
It should be no problem to have the SE B7 with either or both AES/EBU digital input and XLR output as options, and I would certainly agree with that choice. These input/output do not mean internally balanced.
Get the Regen though…it will be worth it.
Ken,
I had usb upton regen with PS by Teddy Pardo on loan from Elberoth. Very often I agree with you wisnon, but not this time though. I sended it back without regret.
Of course the result will depend very much on specific setup esp the quality of transport .
Mariusz, there is another owner of the B7 who says the same thing. And he has a quality transport. I haven't opened mine yet though I have it.
I tried upton with both La Fontaine and Lampi B7 , the integration with the latter was a bit better but still not convincing.
Ken,
Thanks Norman!
Ken
As far as I am concerned, the biggest updates to the Lampi come from the Shun Mook diamond resonators (try the ultra, used price around 600 USD) under it, a good power cable. Then good ICs. I have also introduced the UK distributor and Rob (rjs here), and Audiophile Bill to those mook resonators and they loved it, and the Mook valve resonators make subtle but positive differences.
Tubes make a helluva difference of course, but almost all of us are playing with cheap gear here, so remember that most of the Lampi reviews you read are with tubes nowhere near the original WE 101D or 300b
Yes, more and more positive remarks about Shun Mook with Lampi.
BTW, Ido have a (tested) weak pair of original WE 101d...ST shape, no globe. They work perfectly well in the Lampi!
Can it also use 205d, or 101F?
I just wanted to thank everyone for their helpful advice
This is what I love about this site
Honest answers from people with real experience with the devices
At this stage going to go SE as more options for tube rolling
add XLR output jacks ( as I have more top quality xlr than rca ICs)
And aes input if no I2S input available as I like to AD covert somethings
Kind regards
to all
Andrew
HI Andrew, this is what I am worried about and you need to verify. If you connect RCA from Lampi to RCA of your pre or power, it is SE to SE.
However, just because you have XLR jacks on your Lampi, the Lampi is still SE, while the XLR at the other end is going to the balanced of the pre or power. It might not work as well, but you can confirm.
Yes agreed
it is impedance issue as balanced is different
my system is fully balanced everywhere
i will get rca to rca, but would like option of xlr to xlr in case works as i have great xlr ics
does that make sense
thanks for your interest and concern :)
yes makes sense
If the pinout is the same as the others and the volts times amps is less than 6.5 watts. 300b/2A3 setting!
45 setting for 4.5watts and below.
VT52s work in the B7 and that is pushing the upper limit.
Yes agreed
If your system is fully balanced, then get the BALANCED Dac. You will still have a huge permutation of tube rolls. DHTs can be EML Anniv Globe 45, mesh plate 45, 245, 345, UX301, 101d, WE 275a (vintage , cheapo or WE replica) and quite possibly 6a3 will work too. Then you also have the choice of ALL the 5v rectis, ie 5y3,5u4g,5r4,54r,gz34,gz37, type 80, typ3 83v, 5V4, WE 422, U52, etc.
Bear in mind that its the combo of recti and output DHT that determines the sound and is the greatest manner in which fine tuning takes place. You will have more than enough permutations to keep you busy. Recall that with the Bal Dac, you need matched quads so NOS wont likely be a viable option, you will need new production DHT output tubes. I am hearing great things about the EML mesh plate 45s and will get a pair today for myself to try. A quad of those will be below $1,000, so not outrageous and as you likely know...DHTs in the Dac will last FOREVER or close enough to it.
SE Dac in a fully balanced chain is sub-optimal, to put it mildly. However, if any other element in the chain is really SE, then U should get the SE Dac.
Thanks
Great advice Wisnon
really appreciate it :)
So you think with 45s i won't miss choice of elrog 300s by going balanced?
Andrew
On a related point..
are photos on lampizator site of balanced dac photo shopped
i noted the second set of output tubes have no heat ventilation holes around them making it seem ...erm...unbalanced....can this be right?
does anyone have a picture of an actual balanced dac to check?
thx
A
