Also, raised the VTA a bit on my arm- easy enough to do on the Airline, you can do it on the fly- and it makes a big difference. While it sounded fine at the slightly lower setting, and nothing sounded muddled on the first cut, i'm playing side two with a tad higher VTA setting and it is even more open on top and the bass tightened up, more 3d quality all around. So, add fiddling to the VTA to your list when you play this record.
