Sure Stereo, you know more about what is a fantastic potential in this, and likely will be in a group of one.
Just to clarify: I know of another Ultimate buyer who will go the same direction as me. We share the required development for a 5 ways full active system. I know also of an active WBF poster who has decided to use also the Conbrio for his Q7 system.
It is pretty clear that a well implemented active XO is better… Except costs.
The major advantages of active systems using an active crossover are as follows:
1) Low intermodulation distortion (IMD)
The IMD is low because the power amplifiers work in a smaller bandwidth. IMD is produced from different frequencies that modulate each other producing new frequency products that don't exist in the original signal. The amplifiers work easier and cant effect the other amplifiers. Also clipping from low frequency overloads of the amplifier in multiway active systems is not present because here only the loudspeaker can limit the signal.
2) Larger Dynamic range
A 60W and 30W amplifier in an active system will clip at the same level as an 175W amplifier in a passive system. When a low and high frequency signal are amplified at the same time there is at high levels a sink of the maximum level because the low frequency signal makes the power supply voltages lower due to high current need. That's why active systems always sound dynamic and louder than passive systems.
3) Better Impulse behavior
Great impulses in music reproduction create sudden and high current transients on the way from amplifier to speaker. These impulses from musical instruments hold almost all of the important information about the instruments sound and character and the room acoustics of the recording. So they carry eventually essential information that is needed to reconstruct the spatial sound image of simultaneously playing instruments in a room and this is very critical and sensitive. Any distortion of these characteristics changes the whole reproduction of recorded music so that's why different speakers sound different.
4) Better coupling between amplifier and speakers
Amplifier and speakers are better coupled directly and introduced resonances from passive crossovers are avoided. When you use a speaker cable with larger cross section the sound get better. This is always noticeable. The reason is that with lower output resistance the amplifier controls the load better. It has a better damping factor as known. Passive crossovers have a larger share of resistance losses then the cable and make the situation worse since the passive components produce distortions.
5) Better function of the crossovers that work with a constant load
In a passive crossover the voice coil of the speaker is always a part of the crossover. There is a very big variation in the speakers impedance from low dips to high resistances. This means there has to be a correction circuit that equalizes the impedance to more constant. In an active crossover that is placed before the amplifiers the speaker impedance is of no importance. The cut off frequency and the filter characteristics stay constant whatever the input of the amplifier is. This is very good for the DIYer who wants to experiment with the least mistakes and problems. Even a 24 dB/octave filter is practical without any of the known problem of the passive filters (most important coils and high cost of the passive elements).
6) Better subjectively sound quality
The sound quality of an active crossover is subjectively higher than a high level passive crossover. There is a big difference in working with millivolt and microampere level signals and with high current, high voltage signals. The second had problems like micro phony effect, a lot of solder points, high currents to handle with the least losses and the quality of the passive elements plays a significant role in the overall performance and quality (that's why a speaker like the Magico Q7 uses huge, pricey XO components).
7) Easy level control
Designing active crossovers is easy and there is a great freedom in controlling the different sensitivities of the speakers. When the tweeter plays too loud you can't just put a resistor in the passive crossover to change the level (I know Wilson does that, doesn't mean it is a smart thing to do). It will most possibly change the cutoff frequency or other characteristics of the filter. In an active crossover you can control the various levels through trimmers before the amplifiers like the volume control.
8) Easy design
With active crossovers it is very easy to manipulate phase, time delays, resonances, amplitude shaping...
Those are the advantages of an active system. But someone might ask, is there no disadvantage? Well of course there is. The only disadvantage is that the cost is a lot higher then a conventional system since it needs more discrete amplifiers /DACs plus an extra active device (the active crossover), with a good clock to synchronize all equipments. This disadvantage is mitigated for DIY, who can decide to spend money where it really matters...
Cost is very important though in commercial equipment where low cost is a major matter. Apart from that there is one thing that can make the cost lower. Each amplifier as stated before can be a lot smaller than the one very big one needed in a passive system. As conclusion I think it is worth it.
