Line preamp advice for Herron VTPH-2A
ctor
1
57
I put my system back together after years of not being able to use my mancave. My old preamp failed, and my old amp failed, so I picked up a PS Audio S300 amp and got a great deal on a demo Emotiva XSP-1 gen 2 as a stopgap.
A few months ago, I bought the Herron, which made a significant improvement over the stock phono stage in the XSP-1. Now I'm ready to start shopping for a preamp that will do it justice.
Which is why I found my way here. I have a budget of around $3k. I could possibly go higher, but would need to save up a bit more. I have no real preference between tube and SS, and would buy new, demo, or a recent model used.
So, if anyone has experience with the Herron phono preamp, and can make a suggestion of what would work well with it, or even a suggestion for a neutral preamp, I would greatly appreciate it.
Thanks in advance,
me
gryphongryph
8
If you want something really special and good sounding, take a look at Supratek pre’s they start at $2000 I just got a Cabernet and it sound spectacular.
One needs to be patient and they are hand built in Australia, but these are amps you keep for life.
Happy hunting.
dan31
895
267
413
SF Bay
Consider the Benchmark LA4 preamp. You can include a headphone preamp as the HA-4. Good company.
Phantom-Audio
128
94
115
Jakarta
www.phantom-audio.com
MP-3 would be a suggestion, They can also come with built in Phono Stages.
Phantom-Audio
128
94
115
Jakarta
Atma-Sphere MP-3 would be a very good choice. Excellent Warranty and support too.
