Lampizator Golden Gate upgrade?
kilervideo
15
3
3
64
Hi. It is possible to uprade 6 years old Lampizator Golden Gate or they no longer do it? It got the latest USB board JL SOUND USB.
Golum
1,814
2,577
405
Lausanne, CH
It is possible AFAIK - ping Lampi directly or distro in the country you are located
Reactions: eskamobob1
Golum
1,814
2,577
405
Lausanne, CH
What are You talking about? Did not get a world of it?
Ask yourself what did you ask initially and you will know what I'm talking about. If you don't like the answer just skip it and ask further
kilervideo
15
3
3
64
If it is possible I would like to know what are they changing? New Engine 11 or what else? I know it will cost.
eskamobob1
43
24
13
34
They have the golden gate 3 currently. That will be the end of the line for the golden gate series but it uses the new engine and iirc a different input than the gg2 (but double check that second part).
kilervideo
15
3
3
64
Ok. So should I contact factory in Poland about upgrade?
  • Sad
Reactions: dbeau
kilervideo
15
3
3
64
I would go through your local distributor and see what they say.
Thank You. But the problem it is the unit it is in Europe, so Lampizator Poland will be the most convenient. If You dont know I live in Australia. But can bring it back from Europe.
kilervideo
15
3
3
64
It is not easy to find used/demo model Lampizator with volume control. Can I use Lampizator output but use Anthem AVM70 volume control bypassing any procesing by Anthem? Any thoughs please reply.
msimanyi
Active Member
Jan 13, 2023
144
116
43
Pass your Anthem the analog output from your DAC, and the volume control will work. I’m not familiar with that processor, but I have no doubt there is something like “Reference Stereo” mode where none of the DRC processing is performed.
Blake
260
345
170
I think this point needs a bit of clarification. It is not the case that GG3 is permanently frozen or at the end of product life.
Lukasz confirmed that:
(a) at the time of ordering, a Golden Gate (or Big 7 or Pacific) buyer can request any parts that may might be developed over time, whether now, or years from now (say, Engine 11 for example or a later developed digital engine that might be developed years from now, etc), assuming they are compatible; and
(b) If, after ordering, say 3 years later, wanted to send a GG for an upgrade to get some newer part, that will definitely be possible.
So at the time of ordering a Legacy DAC, you'd just contact Lampi and tell them what, if any, upgrades or modifications you want. They just won't be actively implementing new developments.
