Klipschorns
tmallin
WBF Technical Expert
May 19, 2010
1,191
543
1,685
73
Chicagoland
Klipschorns are one of the most controversial of speakers. In my "90% . . ." thread I mentioned that horn loading is one of the paths some designers take to minimize the interaction between speakers and room. Of horn speakers, the K-horn is probably the most famous and has the distinction of being in continuous production for well over 60 years, longer by far than any other speaker in history. Here are my personal perceptions of the sound of Klipschorns. As I said, K-horns are controversial and opinions not only vary widely, but are usually extremely polarized: listeners seem to either love 'em or hate 'em.
Dynamically, the K-horns take no prisoners. A part of this is undoubtedly due to very high sensitivity of the design at 104 dB/watt/meter. They make even the 95 dB/watt Legacy Whispers I once owned sound dynamically constrained. This is readily apparent on most any program material, but more so on classical "power music" and especially any rock or jazz with a good rhythm section. For some listeners--and on some days, with some material, I count myself as one--this carries everything else before it and the K-horns seem unbeatable.
After the initial excitement goes away, however--and that may not take longer than a few minutes of listening--and especially on reflection when not actually being aurally tempted by their charms, reality hits.
You must have two good solid corners behind the K-horns and they must be placed tightly right into those corners. Even with this, real bass, although very realistic sounding for all types of drums, only goes down to 35-40 Hz or so--deep enough for drums, but not deep enough to energize the room on organ fundamentals.
The tweeters beam and you must listen directly on axis to get true high frequency extension. When pushed into square corners, the tweeters thus fire at 45 degrees to the adjoining wall surfaces. While some owners have taken the top section off the woofer cabinet and/or enclosed the the woofer cabinet with additional plywood, allowing the mid/high horns to be rotated (the 60th Anniversary edition had a closed back as sold), barring such machinations this means that the speakers must subtend a 90-degree angle from the listening position. I like wide separation, as I've said. But many will find this amount of separation too extreme for most material in most rooms. So did Paul Klipsch, hence his recommendation for using a Cornwall or Bell Klipsch as a center mono speaker.
But while that fills in the middle, unless the wall between the corner horns is constructed in an arc (rare outside a converted circular barn), the center speaker will be too close and will require some sort of digital or analog delay in line with the signal, in addition to a volume control, to keep the sound from the center speaker from being severely phase-misaligned with the corner horns. The easiest way these days to time and volume align the center speaker is to use an AV receiver or pre-pro to handle this task.
A listening position where the speakers subtend a 90-degree angle also puts you fairly close to the speakers. This is the reason most people follow Klipsch's original recommendation and put the long wall between the speakers. You will then be 1/2 the length of the long wall from the plane of the speakers. If that wall is 20 feet long, you will be 10 feet away. That spot may be in a bass null or maxima for the room and there is no way to change that result by moving the speaker locations.
There must be no large objects or even surface irregularity on the wall surfaces between the horns or several feet along the side walls. Even wall acoustical treatment seems to kill the bass and severely limit the ability of the speakers to form images and stages. The speakers like live, uninterrupted wall surfaces, in other words.
Listened to on axis, there is good high-frequency extension, but there is brightness and smear in the upper midrange and treble. A substantial part of this is caused by early strong reflections from the wall right beside the speakers. While corner placement minimizes the percentage of wall surface which can act as mirror for reflections of mid and high frequencies, the drivers really aren't exactly in the corner but a couple of feet in front of the corner. Yes, you can pad the corners with Sonex or other absorbent material, but you need a lot of padding, thickness-wise, due to the strength of these reflections since the drivers are so near the walls and the more padding the more you interfere with bass, imaging, and staging.
The close-to-wall-and-corner placement also inhibits perception of depth of stage. In my experience, it is harder perceive stage depth when the sound emanates from close to the wall behind the speakers than when the speakers are set up well out into the room. K-horns are not unique in having this problem when placed near the wall behind them, but I think the corner placement exaggerates this problem by placing the wall reflection spots very close to the drivers. With other speakers, you have more placement choice. With K-horns, you have to live with the sonic products of close-to-corner placement.
The 104 dB sensitivity of a K-horn also reveals system noise and hum you might not realize was there with other speakers.
All that said, yes, I do like to hear K-horn systems in some rooms in small doses. Under the right conditions the sound can be unbelievably dynamic and exciting; truly the band is there in front of you.
Paul Klipsch used to say what the world needs is a good 5-watt amplifier to get the best from his horns. Many K-horn owners gravitate toward tube amps, particularly low-wattage SET types. In my opinion this is wishful thinking. Horns and SETs go together because horns are the only speakers efficient enough to produce decent volume and reasonably lifelike dynamics with amps having no more than 40 watts per channel, most with less than 10 watts.
Yes, with most speakers SET amps are usually "sweet" sounding, but that is basically because they both roll off the extreme highs and warm up the mid-bass. They are also "easy on the ears" since they constrict dynamics--in combination with their sweetness, this makes them sound polite or at least non-aggressive. There is never any truly deep bass from SETs, even if hooked up to a speaker which is capable of it with other amps.
What sets SETs apart is the way they sound in the midrange. Again there is "sweetening" going on, but this time it's because these amps have relatively high amounts of second harmonic distortion, as opposed to the 3d harmonic and other odd-order harmonics common to most transistor gear. Research has long showed that people actually like the sound of added second harmonic and that in fact there is almost no reasonable upper limit on the appreciation for such. And, if you push an SET amp toward its power limits, if it is designed properly it will just increase its amount of midrange 2d harmonic, and reduce bass and highs due to bandwidth limiting at higher power. Fletcher Munson effects reduce the audibility of the reduced bass and highs and you get more of that "magic" midrange due to the added distortion. Some find it addictively smooth and relaxed. I just yawn.
Lots of K-horn users swear by SETs. I think the reason is that the bass limitations in the lowest octave aren't apparent and that the sweetening of the highs and midrange mentioned above counteract to some extent the brightness smear and other irritation inevitably caused by corner placement and othe factors.
Those other factors probably include the choice of drivers and the characteristics of the midrange and treble horns. Some K-horn owners have very good ears and have worked hard to conquer or at least alleviate the brightness and irritation in the upper ranges through more radical measures than merely choosing sympathetically colored amps. Greg Roberts of Volti Audio may have the ultimate K-horns on offer. If you take advantage of all his mods, what is left is only the basic K-horn cabinet; all the drivers, wiring, and crossover components are replaced, and a new veneer can be added. Others have tri-amped the K-horns with DSP used to cross over and time align the drivers.
On the other hand, you must remember that the K-horns sell for "only" $8,000 the pair. Compare that to the pricing of the Avant Garde horn models, for example. I would much rather listen to K-horns than the $10,000+ Avant Garde Solo. The Solo is quite colored in the megaphone sense. The larger Avant Garde models ones have less of that but are incoherent (separate sound sources quite audible) unless you are back pretty far. The Solo has no real bass; the more expensive models in the line have non-horn bass which I don't think keeps up with the rest of the dynamics.
No, the Avant Gardes don't have to be in corners so you don't get the inevitable brightness/glare from wall reflections like with the K-horn, but I find their vowel-like megaphone colorations harder to listen around than the Klipschorn colorations, and the Klipsch are certainly vastly more coherent from close up, and have much better bass. I have never had an adrenaline rush from the Avant Gardes, whereas that is very common with K-horns and live music. Overall, I think the K-horn is a reasonable alternative to the larger Avant Garde models, at a small fraction of the price.
The Legacy Whispers I previously owned are advertised as having that dynamic "breath of life," and I agree, that compared to most speakers they do. But compared to the Klipschorns, they fall short in the department of fooling you that the music is live when you are only paying partial attention.
Also on the positive side, the K-horns, do the "live in the next room" thing much better than most other speakers. I have never heard a satisfactory (to me) explanation of what aspects of a reproducing system are important for that effect--it surely isn't frequency response or anything to do with spatial effects.
Bottom line, as to stock Klipshorns, I tend to agree with the sonic comments made by Richard Heyser in his review of them in Audio magazine many years ago. You can see this review by linking to each separate page of the review from here.
Nice Tom
I am surprised you yawn at SET's. Is it because of the decreased bass response
No bass, colored mids, not very extended treble, no dynamics, a lack of real clarity. Speakers connected to them tend to sound like polite table radios. A generalization, I know, but I have yet to hear a SET-powered system which I thought sounded realistic in either a tonal or dynamic way compared to beefier modern solid-state amps.
when will you be in California Tom as I would like to have you hear my SET-up (pun intended). I am hoping to prove you wrong
Wilson X-2 Series ll and Lamm ML3 Signature a 32 wpc SET using a DHT GM70 output tube and Lamm LL1 Signature preamp
At $140,000 a pair, they'd better be "What's Best" on the planet in terms of SETs, Steve. I haven't heard them. But I see some were impressed at a show by Wilson Maxx speakers driven by this amp. And with a high efficiency speaker like the big Wilsons (94.5 dB/watt/meter according to Wilson), the amp should be able to play the speakers loud enough.
But just to keep you from sleeping well tonight, I'll suggest that the 32-watt limit at 3% THD (Lamm's spec) might be the reason you need a pair of JL Audio Gotham subwoofers (each with a built-in 2,500 watt solid-state amp) to fill in the low end of your Wilson X-2 Series II speakers. SET watts may sound bigger, but when it comes to moving and controlling big woofers, 32 watts will only go so far in terms of SPL and control, especially if the distortion is climbing rapidly near the limit as it apparently does. Frankly, 3% THD at 30 watts output at impedances of 4 to 16 ohms (Lamm's spec) would be embarrassing for even a $250 amp, much less one costing this much. Tonight, with your head on your pillow, think about what your system might sound like with a $16k pair of Bryston 28Bs throwing 1000 wpc or more with virtually no noise or distortion at the Wilsons. You could sell the Lamms and the Gothams and with the change you pocket, buy a top-line BMW . . . . :)
Tom
you need to read my list of gear as I do have a pair of Gotham subs in my system
I love that Bryston amp Tom but when the dust settles every day I am firmly in the tube camp
I did read your list of equipment, Steve. That's why I said that your use of the 32-watt Lamm may be why you need the Gothams to fill in the low end. But maybe I'm just yanking your chain, right?
I'm thick skinned Tom. it wouldn't be the first time. BTW, the edit above was my mistake when I started typing in your post rather than as a new reply. Ah the powers of an "admin" ;)
With the X2's, Lam3 and 2 Gothams, OB gets the best of all worlds. My personal theory is that the distortion from the SET amps keeps the X2's from sounding clinical. Instead, the combo is pure magic. OB has also taken the all out assault approach by supplementing his bass with the addition of the two Gothams, relieving his SET amps of the duty. Thus, he gets the tube sound for mids and highs from Wilson X2's + solid state from the Gothams for incredibly deep and articulate bass.
I'll have to check in on this after I receive the Oswald's Mill Audio horn speakers that are being prepared for me. I'll make an announcement about these in the next number of weeks, report in on their performance and post photos in my system thread. Until I receive the speakers I am not at liberty to discuss any details.
Rich
I'm glad it was you, not me, who called the Wilsons "clinical."
Tom, you really need to take a trip out here to California ;)
Hi Tom:
Sure did enjoy your write up on K-horns. Of all the speakers that came and gone through my house, I still have an original 1976 pair - resting at the moment. Your article has inspired me to get them cracking again. I had tried the ALK horn and tweeter upgrades and have tried to separate the horns from the bass bins, etc. but always came back to the original configuration. We have a forum member, Jay, who could elaborate more on the latest Greg's mods.
As for the amps, the first tube amps I tried on the K-horns were the Heathkit W5Ms. They had almost no noise even with my ears right up to the tweeters and mid horns. At about 15 w/ch, it is a clean - maybe too clean. Although the K-horns are very sensitive, I also tried EL34 amps such as the Marantz 8B and AudioPrism Debut II Signature and KT88s with Citation IIs. For a while I ran them with Wight Audio 2A3 fea power (~3W/ch) amps... Of all the amps, I do like the 8B the most with the K-horns.
K-horns are the only speakers that can be playing piano music upstairs driven by the 8B, and I get mistakenly thinking my kids are playing the real piano whereas the piano is located downstairs... However in critical listening set up, I could never get the type of imaging I get from either the panel or dynamic speakers positioned away from the room boundaries.
Ki
Tom,
Interesting article on the KHorn, definitely a true classic of the audio world. Of course I am a long time Khorn owner so I would tend to disagree with you on much of your analysis and commentary of this great speaker. There's a simple reason why KHorns are the longest running produced speaker of all time; people like them, like them a lot... After thirty or so years in this crazy hobby I am still amazed at the great diversity of speaker designs available. Some are good, a very few are great, and most are still average, or worse, downright terrible!
I wouldn't disagree completely with many of your comments; you are correct, KHorns do not throw the deepest sound stage that can be had, they do beam a little in the treble, they can loose the center if spaced too far apart, they do sound best when you are seated dead center (as do most speakers), they can pin your ears back when matched with inferior equipment (and a with a lot of solid state gear), and they do absolutely require an excellent room of the proper dimensions with uninterrupted corners, and they do sound best with tubes and vinyl (but heck, so do most speakers).
Having admitted and agreed with all that, it can be said however, that with carefully chosen ancillary gear, especially with good quality tube amplification (say with a good EL-34 push-pull amp) and with good quality vinyl on the front-end, what you do get is one of the most exciting to listen too and most engaging, live and life-like speakers on the planet! When I play a good live recording of Johnny Rivers at a Memphis club, what I hear is REAL; so real in fact that with the lights down low or completely off, I can honestly really begin to believe that I am sitting in this dark, somewhat seedy and smoky club, with beer drinkers and smokers all crammed around, and the goosebumps will actually rise on my arms and/or the short hairs on the back of my neck will stand up...
Recently I purchased a pair of Magnepan 3.6's; my 17.5 x 26 x 9.5 room is a good match for them and they are easy to move to one side whenever I want to switch back to my KHorns. I agree with the majority opinion; the 3.6's are very, very, good speakers. They sound wonderful. Of course, most tube amps cannot drive them properly so I did have to pick up a good stout SS amp with plenty of current. And, I would also agree that, there are a number of things that I like a great deal about the sound of the Maggies, such as the nice wide and deep sound stage, the very convincing and very sweet treble, the realistic size of the images of instruments and performers that it paints across the stage, and their fine transparency that allows me to hear way into the music. In short, the Maggies definitely outshine and outperform the KHorns in some areas. (And, a set of 3.6's can be had for under $5k which is significantly less than even the KHorn). But when it comes time to rock n' roll, to really hear the swing of live music, to transport yourself into the live music venue, it's still hard to beat a properly set-up set of KHorns!
I guess I feel very fortunate and lucky to have two very fine sounding transducers!
As I said in the first paragraph of my post which started this thread: " K-horns are controversial and opinions not only vary widely, but are usually extremely polarized: listeners seem to either love 'em or hate 'em." You are obviously in the "love 'em" camp and I respect that. A currently (2025) active link to Richard Heyser's Klipschorn review is here; scroll down to page 64 of this pdf copy of the November 1986 Audio magazine where the review originally appeared.
By the way, you may want to take a look at Issue 205 of The Absolute Sound, the latest one. There is an article called "The 12 Most Significant Loudspeakers of All Time." Eight TAS reviewers named their top dozen picks for this list. The K-Horn came in at #12 with four reviewers including it on their list. Not a bad showing for a controversial design.
Of course, the vintage AR-3a speakers I have and admire so much was named on all eight lists and, to my surprise, came in at #2 on the list. Number 1? That's easy and no surprise at all: the Quad ESL-57.
Reactions: NickMimi
Wow, a blast from the past. And I do mean "blast"... :)
I have heard many (probably most) KH's that sounded awful, and a very few with proper placement, proper room treatment, and good electronics that were amazing and blasted all my notions of how obnoxiously loud and shrill they were. And, I met Paul a few times -- what a neat guy! A bit cantankerous, perhaps, but just a wicked fun guy to hang with... One of the audio rags of the 70's/80's (might have been Audio) had a write-up that including a lot of his sayings, fun stuff!
Thanks for the reminder - Don
Tom,
Yes, I subscribe to The Absolute Sound and have read that article; very good commentary on speaker history... Wasn't trying to be argumentative; like you said, KHorns can be one touchy subject! Interesting that you mentioned AvantGarde Horns (and I thought that your comments were right on target) because I spent some time auditioning them seven years ago and ultimately came to the conclusion that overall KHorns were better. There are a number of great looking German Horn Speakers out there but for the most part the ones that I have heard are way too 'hot' on the top...though several of the Acapella Audio Arts models that I have heard at RMAF sounded very good...but unfortunately they cost a small fortune (very over-priced in my opinion). When it comes right down to it though, the main reason horns can be so good is that because of their extreme sensitivity they are the champions of portraying micro and macro dynamics and like Paul K said, that is where the emotion is in music.
Wish that I had a pair of AR-3a speakers to audition; not sure that I have ever heard those.... Bring them to this year's RMAF; it would be really neat to have a display of vintage gear at the show... Maybe I will make that suggestion to the organizers...
