Italian top cable KURO
gian60
2,556
2,060
493
I want to speak about this italian company producing cable since 30 years named KURO
This cable are made with copper 7N solid core with Mu Metal inside to shade and with alpha gel to stop the vibration
Use the jack of Bocchino and the cable are screw to the jack and not solder to avoid lost.
this are some of characteristic of this cable.
I am changing all my cable with this.
I have MIT MAX PHONO and trying this phono i found much better in everything,for example
For amp i have CH Precision cable and this are better with CH electronics.
Also for power are very special
Fantastic are also the power distribution using ATL Audio Grade schuko,all made with Ergal and bronze,cable copper 7N solid core screwed and with alpha gel to cancel vibration.
Price very cheap against top cable,buying directly from him
I post some photos
Regards
Gianluigi
Reactions: vladinsky
Hi Steve,how are you?Its all ok?
Hello to marty when you listen him.
it was a very big pleasure received you and Marty
I post some photos
Regards
Gianluigi
Buona sera Gian,
I see these cables look interesting but I can’ Find any website. Do you have a link please ?
Thanks
He has not a link
He is alone to produce,if you are interesting to have some news you can send message to me and i give to you mail and phone number.
His cable use copper 7N solid core with electromagnetic shield in Mumetal plus double electric shield in copper with dielectric in teflon high density with cotton and silk and a basalt sheath to cover the cable
He use special connector like Bocchino and screw the cable instead to use tin.
Now is doing a new cable,similar,but instead use copper 7 N he found Silver 1000 solid core with 2 bath in gold 24 K
We will try soon
Regards
Thank you for the answer,
For. Ow I am using Duelund tinned cable for speakers and interconnect’ but I am looking for good power cables. I have no idea of his proposal and prices but I’d like his email if you agree.
Thanks
Looking forward to try the Phono cable. It should be stiff like Siltech.
Gian is a hunter for a white elephant :).
Tang
He has not a link
We will try soon
Regards
Why :confused:???
david
Those connectors are the same as the old Audioquest WEL Signature RCA plugs, and old Wild Blue Yonder XLR (except with gold dipped parts instead of silver).
Fantastic connectors, but I’ve never seen them anywhere but on AQ cables. I thought AQ designed them for their own exclusive use.
