I have Tannoy Westminster Royal speakers, I like their sound but they miss something what I hear from some other great speakers, perhaps more resolution, more spark. Alsou tehy require proper room, I have it, they are very sensitive to quality source, amps, cables. Now I am searching for the last piece preamp to complete my mission TWR to sing at their best. But it seems it will also be the most difficult task. Friend of mine suggested to purchase other speakers to compare them with Tannoy thinking that for the money I will spent for preamp I can get better results with diffrent speakers. my budget was up to 15000 euros. I was thinking about this idea and thought hmm, maybe so. I have spent 10 years with TW and maybe I should try something else to see if my taste of sound developed some other way, I do not listen as much to rock music, I listen all kind of music now, a lot of jazz, some classical and other style, even electronica, ofcourse old rock and progressive still remain in my list of the most favorites. It happened that I found these monsters top of the line of Horning hybrid system - Horning Agalme. Since I am a bit megaloman I thought that would fit my bill. They are huge, tall 2m, deep 70cm, they have 12x bass 8inch Beyma speakers in the back in Horning hybrid set up and one tweeter and the baddest Lowther drivers of all PM65 in front. These speakers are exceptionaly revealing and transparent, especialy on classical music and jazz, excelent bass, incredible resolution. The problem is,it is not universal speaker, for some people that would not be acceptable, it does not play Black Sabbath a metal very well. But people who listen classical, jazz,soft rock, progressive rock or even electronica are in the heaven with these, you can hardly find speakers to play this way. Speakers going very low 16_20000hz and the bass is very very tight even when producing the deepest notes, it is pleasure to listen acoustical music of any kind, so clear and real in the space nicely separated. 3D is also very very good. They are totaly diffrent then Tannoy WR of course so for me it is hard to get acustomed to that sound. I am not sure if I want to keep them since I listen all kind of music but they will behard to sell, they are tall 2m so they need bigger room. I forgot to mentionrest of the chain. The source is steraqming transport Pink Faun Ultra 2.16, dac Mola Tambaqui, Jorma aes ebu, going directly through Jorma Origo rca to Emirate SE-833 Challenge which create monstrous power of 80w per channel in single ended Class A and finyly through Jorma Prime speakers cables to TWR . When I applied the same system to Horning Agalme I found out that the sound is to thin for my taste,yes hugely transparent a nd resolving but it was to much for me and unlistenable when I compared them with my TWR, it misses the body of the instruments, it did not create the atmosfere like with my other speakers. It happend that I had NAT magnetic preamp on loan which I did not like very much with myTWR and I thoght to try it in this set up. Wow what a change with this preamp, suddenly the body of intruments got whatis required - the body,now I could listen to it. SoHorning also reveal the weakest ling in the chain. I heard these speakers in the seller s house with analog and I new something is wrong in my chain, could be Tamabaui as a preamp? Could be Tambaqui as dac sounding to thin? That let me thinking maybe I should try some other DAC like Aries Cerat HelenwúKassandra or Lampizator Pacific, maybe Horning would get fuller sound and that is what I think they need. Any thought, advices, experiences?
