Help with speaker placement-
bebop86
79
1
83
Guys I have a 17x27 treated room that I want to put my Classic Audio t1.4 Horn speakers in- Normally I use the triangle of equal distance between speakers and listening position-= I just tried the Cardas and Real trap calculators and it show that I should have my speakers around 7 feet apart and 14" from listening position- This seems to close together for me but it also goes against what I always heard about speaker placement - Any advice- thanks
GaryProtein
2,542
31
385
NY
TRY THESE LINKS for speaker placement. I hope they are all still active.
TAD speaker set-up
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/420272384TADR1OwnersManual0228.pdf page 11
THIEL speaker setup
http://thielaudio.com/THIEL_Site05/Pages/FAQs/faqplacement.html
MARTIN LOGAN speaker setup
http://www.martinlogan.com/pdf/manuals/manual_scenario.pdf
GENESIS ADVANCED TECHNOLOGIES speaker setup
http://www.genesisloudspeakers.com/whitepaper/Genesis_Loudspeaker_Setup_Procedure.pdf
AUDIO PHYSIC speaker setup
http://audiophysic.de/aufstellung/beispiel_e.html
WILSON AUDIO speaker set-up
http://www.wilsonaudio.com/pdf/manual_soph2.pdf
CARDAS speaker setup
http://www.cardas.com/pdf/roomsetup.pdf
EVOLUTION ACOUSTICS speaker setup
http://www.evolutionacoustics.com/support/speaker-placement/
and go to the support drop down menu for room type
rbbert
3,820
239
1,000
Reno, NV
Or, you could just use your ears....after all they are the only ones that need to be satisfied.
You still need to know where to start, and most of those methods above provide not only a starting place (often found by "using your ears") but then fine-tuning advice (always "using your ears")
JackD201
1,425
1,820
Manila, Philippines
Hi Bebop,
As you know the directivity of horns does allow them to be closer to side walls than more conventional loudspeakers. If you think the cards method has them too close together, my take is that your instincts are correct.
Cheers,
Jack
