have you checked the Devialet volume ? I'm using jRiver and I can also change the volume using the jRiver volume slider. But it is changing the volume of the Devialet itself, so it is still bit perfect.
Hi
Just another question in this Air Times
witch external powercabel will fit the Devialet ? so far havent found any ?? using a naim one today but can have the cover on
Was sure Shunyata would but now been told its also have to big connector into the player
Devialet told me in Munich not to bother with different power cables. And I certainly wouldn't use Naim which is specifically designed for their own equipment
Hey Ian!Just had an email from Devialet:
"The software team responsible for Air just discovered a bug in the buffer management which gets corrupted as time increases. So what you experience at home (no problem during a couple of minutes and increasing problems after) is expected with the current version of Air. This shall be fixed before my venue (visit) to Oxford next week."
So that is good news.
Dear Philip,
Thanks for your message. We are working real hard on the corrective update. We will release it as soon as we possibly can.
Best regards,
Thierry
Dear Devialet,
I've reported the issue earlier but I will do again after reading the 'The new Devialet AIR help' article. I will supply you with all the requested information in that article.
Devialet D-Premier, serial number: x, AIR 2.0, firmware 6.0.6. WiFi strength steady around -21/22dBm.
Computer is a dedicated "NAS" PC (fully updated (BIOS, drivers, windows update, software):
OS:Windows 8 Professional (64 bit)
Case: Lian Li PC-A04, mATX
Motherboard: Gigabyte GA-H77M-D3H S1155 H77 4xDDR3 mATX
CPU: Intel Pentium G630, 2.70GHz, 3MB, HD1000, S1155
Memory: Corsair ValueSelect 8GB(2x4GB) DDR3 1333MHz CL9
Disks: 2 x 3TB Seagate Barracuda 7200.14 in RAID 1 mode
no keyboard, mouse, screen or USB devices connected
All music (CD rips) is stored on the NAS PC as ALAC files, mostly 44.1kHz, 16 bit. Ripped using dBPowerAMP.
Network setup:
- NAS PC connected wired to TP-Link gigabit switch, set to 1gbit/s, full duplex
- ASUS RT-N66U WiFi router (latest firmware: 3.0.0.4.370_172)(configured as N-only access point, channel 6, 20MHz channel, best channel according to InSSIDer) connected to same TP-Link gigabit switch)(set to 1gbit/s, full duplex, dedicated network)
- Fritz!Box 7360 ADSL router (latest firmware: FRITZ!OS 05.51) connected wired to same TP-Link gigabit switch. (all unneccesary functionality like WiFi, uPnP, telefony etc. disabled)
- The Devialet D-Premier connects wireless to the ASUS RT-N66U accesspoint.
- Remote control using iPad 3, connected wireless to ASUS RT-N66U accesspoint.
All devices have an IP address in network 192.168.1.0/24. (DHCP server=Fritz!Box)
WiFi noise (reported by ASUS RT-N66U) varies between -84dB to -88dBm.
PC setup:
Power management -> maximum performance
installed AIR2.0 using 'run as administrator'
default settings Devialet AIR2.0 (WASAPI bit perfect disabled, switch never, 16 bit, 44.1kHz)
reboot PC
disabled all running programs, background programs
Turned of iPhone and TV (which also has a WiFi and BlueTooth interface) so no other devices are active on my network.
Restarted all network devices before testing.
Issue:
Regardless of chosen buffer size music plays fine for a number of songs. After about 15 to 20 minutes dropouts start to occur (silent hiccups shorter than I think half a second). These dropouts occur more often over time while playing.
After restarting the AIR2.0 client everything works fine again for 15-20 minutes then again dropouts start to occur. Restart AIR eveything is fine again etc. etc.
Tested with both iTunes 11.0.2/3 and 4 and J River Media Center 18.0.194. In all the issue occurs.
Experimented with the process priorities of AIR2.0 (highest and realtime): no effect.
AIR 1.5 has always worked fine in my setup. Downgrading to 1.5 and firmware 5.7.3 immediately resolves the issue: no more hiccups/dropouts.
Hey Ian!
Did you hear anything concerning buffer management problem the last days from Devialet by mail? I now wrote a comment directly on the helpdesk from Devialet - here. Not even the dealers are informed of the bug as I could establish yesterday. It is not a non good trouble management so far concerning some official information - it is no trouble management at all. In my view the money you pay for a Devialet is enough to include a much better service in kind of (home-made) trouble - for the purpose of user information. For what else do they have btw the eMail adresses of the users for example?! Would be no more than pressing a button.
Hi
I have heard nothing more personally from Devialet. There has been nothing put on the website by Devialet. As far as I know Devialet has not briefed dealers. Not good.
Lol, so in an attempt to normalize everything again, I went back to Air 1.5 and 5.7.3. The app on the iPhone/iPad no longer works with the older versions!
... well it would have been had they delivered on their promise. "Before my visit to Oxford" = Tuesday. Visit to Oxford = Wednesday. Today = Thursday. Still nothing. No update on website. No email. No new 6.0 or 2.0. Poor service.
@HPetter @DEVIALET There's a fix on the way; we have to be patient; it is less frustrating to downgrade to 5.7 and AIR 1.5 till it's sorted
Less frustrating would have been to remove the update from the site and open handling as soon as they have been aware of the problem. That is weeks ago.(...) it is less frustrating to downgrade to 5.7 and AIR 1.5 till it's sorted
