Best (and Cheap!) under Amp Isolation?
Feb 7, 2015
30
Naperivlle, IL
#1
All,
I'm looking for some recommendations on isolating my Air Tight tube amps (ATM-2's Mono'ed). I'd prefer to stay away from mega-expensive "audiophile type" devices and go with something that accomplishes similar results without the large outlay of cash. I'm not sure if isolation, as opposed to coupling, is the best way to go; but I have a suspicion that it is. Due to the weight of the output transformers on my amps, they are quite heavy (approx 80 lbs each). So I would need to use something that can support a lot of weight. I'm currently using carbon blocks to support my line and phono stages - to somewhat effective results. My turntable is resting upon a 5" Maple Boo's Butcher block that's suspended upon three Nordost carbon/metal cones (not sure exactly which ones).
I'm not opposed to trying something that requires some DIY effort or shelling out a couple of hundred bucks.
Here's a picture of my set-up if this helps with suggestions....
Thanks!
Kyle
DaveC
2,521
376
83
#2
Wood blocks and Herbie's extra-firm iso-cups + balls (balls are made of various materials) are worth trying out ime.
Likes: scericson
XV-1
1,841
234
63
Sydney
#4
auralex gramma amp platform. Less than $100 each.
I use them under my ss and tube amps.
the sound of Tao
1,262
701
113
#6
IKEA laminated bamboo cutting boards or Carrara marble slabs are my traditional material of choice over hardwoods or granite tho would be happy to also explore delegnit (phenolic resin treated laminated birch) or tank wood etc as used in Kaiser Kawero speaker’s, turntable plinths plus maybe even some of the Taiko gear not to mention tanks, railway and truck carriages and fire resistant, bullet resistant structures.
Super tough and so a bit harder to work with.
Mar 3, 2011
108
5
18
#7
I would second the Auralex option. You can buy just to try if they work in your system or not, price of entry is reasonable. Alternatively, when I had the Airtight amp for a brief period of time I used the Taoc platform. I didnt compare it to any other platform when used with Airtight, however. The Taoc has a sound character that was very evident in all equipment I used with, on the darker side of neutral. A different but pricier option is the critical mass. It ended my eagerness to try this and that.
DaveyF
6,135
133
63
La Jolla, Calif USA
#8
One of my a'phile buddies uses an interesting solution...he uses Sound Anchor speaker stands ( the smallest ones) under his amps. Works very well and not particularly expensive. Plus they can easily handle a lot of weight.
Jan 29, 2012
1,215
333
83
#9
All,
Thanks!
Kyle
Killer Air Tight system, congrats. What speakers are you using? I second DaveyF's recommendation of Sound Anchor, world class looks and sound for less than most racking systems available today.
