Microstrip,
Since no details are given in the different papers as to what electronics etc. have been used, you cannot say that conditions were different from the ones typical for audiophiles. However, I strongly suspect them to not use fancy cables and massive power amps with inch-thick faceplates.
Pandora’s Box: as long as differences between electronic components and accessories are determined in non-controlled listening tests only, I for one don’t see any reason at all to believe that such differences actually exist. Coincidently it was also Toole who has shown that the knowledge of the identity of the DUT has an effect on the results:
* Toole, “Hearing is believing vs Believing is hearing : Blind vs sighted listening tests and other interesting things”, AES paper 3894
There are other voices that say that testing should be done blind:
Jon Risch, “A user friendly methodology for subjective listening tests”, AES paper 3178
Further, Toole’s research is not about active vs passive but about how loudspeakers have to behave in order to be subjectively good, and passives can do that equally well. There’s another AES paper that tells how the perfect loudspeaker should look like and what makes a good sounding loudspeaker:
John Atkinson, “Loudspeakers : what measurements can tell us - and what they can’t tell us”, AES paper 4608
It will perhaps come as a surprise that JA is in agreement with Toole: “..but the definitive answers are to be found in Toole’s comprehensive 1986 papers. Nothing that I can conclude from the past eight years’ work … is in serious conflict with his findings.”
When I was shopping for speakers back in 2001, I applied Toole’s results and only considered speakers with good measured response, and there were not many.
Both Klippel and Toole (and JA, see above) found that frequency response and power response are the most relevant parameter to subjective impression. Correlation for parameters such as phase response and distortion was weak. Still, it certainly does not harm when going for speakers with low distortion and zero group delay.
Klaus
This subject is a common source of disagreement. Toole did only establish correlation between some measurements and statistical listener preferences in well defined conditions, that are far from the typical conditions used by high-end audiophiles. His opinions about electronics and audio accessories such as cables and power devices are well known, and I respect them, but I disagree on them. If your criteria on sound quality is the same as used in the references above I can partially understand your endorsement of actives.
However, not all people have the same weighting of the multiple sound quality parameters as the Harman group. What you and others consider weak or non conclusive can be strong for audiophiles.
Klaus
