Troy Crowe is doing a custom build for me which will resemble these.
The question is that with the 3.1 system I want to build for DVD and BD movies, would I likely notice the main speakers playing much when watching movies, if indeed like ELAC, SVS and Definitive Technology say that ~ 70% of the movie soundtrack is intended for the center speaker? If yes, then with just music listening, since I don’t play any multichannel music, the center channel speaker won't even be playing with stereo and mono recordings.
So, will timbre matching between center and main speakers still be very important when watching movies? If yes, the trouble is that Troy Crowe gives no recommendations for a center speaker.
Therefore, how to find a center speaker that will blend best with that ES450 horn and Fostex T900A bullet tweeter?
3D CAD files --- Horn No.1994 -- ES450 Biradial for JBL 2446 2" Throat
The horn achieves a 450Hz cutoff frequency (Fc). We recommend a crossover point in the 600Hz-800Hz region so that a standard 2nd order crossover slope can be achieved to match slopes with the low frequency driver's low pass function. Features 3D CAD files of upper and lower halves of horn...
josephcrowe.com
