i had three of these;Hi Mike:
Are you specifically referring to our UpTone Audio EtherREGEN?
I ask because:
a) Since the 2015 introduction of our USB REGEN (the pioneering first device to use a USB hub chip, good clock, and fine regulators), the name “REGEN” has become a bit like “Kleenex” is for tissues.
b) I’m puzzled as to your saying you “owned at least 3 EtherREGEN products…” Why would you have three of the same model? (It has not changed and is still the ONLY network switch in the world that puts Ethernet signals through active-differential digital isolators and differential ultra-low-jitter reclocking flip-flops in a separate data and power domain.)
c) Our order records show that, of the 3,500 EtherREGENs sold since December 2019, we never shipped one to you. I do however see that you purchased 2 units of our original USB REGEN—in August and September of 2015, as well as our choke-filtered, dual-output, 5-7.4 amp JS-2 linear power supply, also in September of 2015. But those are vastly different products than our highly advanced EtherREGEN.
By the way, I see from your signature link to your system that you do use the expensive Nordost QNET switch. I hope you enjoy that.
Someone finally sent me a photo of its PCB (I never understood why some audio manufacturers are afraid to show and explain the technical aspects of their products), but sadly, other than its novel round shape it is a completely conventional Ethernet switch design. Yet that seems to be the norm these days…
Here’s what goes into our baby. The board you see—parts and assembly—costs us over $300 each. But we still change just $680–in a case and with 2-year warranty and personal support.
Let me know if you’d like to try one sometime.
Cheers,
—Alex C.
USB REGEN
The REGEN's primary function is to generate a completely new USB data signal from a carefully chosen USB hub chip running from an ultra low-noise regulator and low-jitter clock—which it does with ideal impedance matching and right at the input of your DAC. Its secondary function is that it...
my apologies to you for that error. it's been 6-7 years ago. will edit my post to reflect that difference. thank you for the kind offer to try your switch, i may take you up on it.
best regards,
Mike
