Looking for anyone that has successfully integrated the CR1 crossover and is loving the sound and music with it
I see you use the Wilson Crossover...do you prefer that over the CR1? If I were to consider dual subs, and experimenting with NOT running the XLFs full range (possibly cutting them off somewhere between 32-38hz, would you think the Wilson Crossover would be the best crossover option...and more importantly, do you think objectively (not just relative to CR1) it would do a good job...or would you advise as above...and not run high frequencies through it?I have used the CR-1 several times. In my own system as well as others.
What are you wanting to do? Are you wanting to use it as a low pass for the subwoofers only or are you trying to roll of the main speakers at 80Hz etc? If you have a highly resolving loudspeaker I don't recommend running your high frequencies through it.
Thank you very much! Let me see if I can get a sweep. I think the one I have was from our other room. In this room, we are roughly flat to 25hz and then -5db at 20hz. This is according to the Wilson dealer who installed the XLFs and was kind enough to set up the Velodyne DD18+ for me (running completely in parallel, not cutoff at all of XLFs).I forgot to answer the question on high passing the mains. I have not tried that withe ActivXo so I can't really comment on it. I would be very skeptical about doing it. Once a system reaches a certain level of transparency there is just no it is not going to damage the sound.
If I was going to high pass the mains then I am thinking I might as well look at a product like the Bacch SSP dio or adio. I could then HP the mains and carefully use some of the other features. But I don't know about that either. It would definitely be a trade off. Some good stuff but another noisy digital box to contend with.
Do you have an REW frequency sweep from 20-100Hz that you could share? You could PM if you don't want to post it.
Hello Lloyd,
Comparing the CR-1 to the ActivXo. IMO, the CR-1 is noisy. This was easy to hear with guitar or plucked strings etc. I would not advise running your highs through it. The ActivXo has a lower noise floor so if you are wanting to high pass the mains I would say to go with it. Honestly, there are not a lot of good solutions on the market for this type of thing.
Fundamentally there are some technical differences between the two.
1. The ActivXo has gain control. It has a knob that can increase/decresae the volume of the left an right independently. There is also a global gain knob. The CR-1 has no method of changing the volume of the subs. It is assuming you are using active subs an can control volume with them.
2. The CR-1 has a choice of 12 and 24 dB/Oct slopes. The ActivXo has a choice of 12 and 18 dB/Oct slopes.
3. The ActivXo has continuously variable phase. The CR-1 does not.
3. The CR-1 has a couple knobs that can adjust the gain right at the crossover point. So it is possible to smooth the frequency response at the crossover point with the CR-1. I believe this is the CR-1's solution to continuously variable phase.
4. They both have a lower cutoff of 30Hz for the LPF. They both can be set to either stereo or mono subs. They both take single ended and balanced inputs/outputs. They both have variable crossover points.
I've never found the CR-1 to be anything but very transparent and very quiet.
That is what i have been told too, considered it a while ago.I have used the CR-1 several times. In my own system as well as others.
How was the Pass, it looks like a great crossover ?As have I... The only other hw x-overs I have used are the Wilson and Pass.... The CR-1 is perfect for my JL "system".
What do you mean by “resolving”. I’m curious what characteristics of a speaker you think should not be controlled by the crossoverThat is what i have been told too, considered it a while ago.
If a crossover adds some noise or takes away some of the information i have fought so hard to obtain trough a all analog chain, it is not for me. My sub-towers are passive, a crossover without ample phase adjustments is just not good enough for my system. When i integrated sub-towers with my MBL 101 E speakers i ended up not connecting the built in sub-driver, running mains with passive filter only and sub-towers with active crossover at 100 Hz, 24db slope. It was just more transparent/resolving.What do you mean by “resolving”. I’m curious what characteristics of a speaker you think should not be controlled by the crossover
Very limited adaptability, only 12db slope, and no phase adjustment, lowest cut frequency 63 HZ. Maybe good instead of a passive crossover on a full range speaker, not good for setting up more complex speaker system.this one is pretty good, i've read. and it's going to be very transparent. but cost you too.
Crossover ACN400 | CS Port
Analog crossover network with "transfer function G=1" without phase rotation. 2-way, 3-way, 4-way, and 3D configurations are available.www.csport.audio
