A question. CE certificated?Reiki audio. I already had a good audiophile switch. The Reiki totally killed it. It is transformative.
Do you happen to know if this an original design and manufacture?Reiki audio. I already had a good audiophile switch. The Reiki totally killed it. It is transformative.
Its hilarious that adding three boxes and four power supplies would be called "minimalist".You might find that interesting to read. https://gy8.eu/review/magnificently-minimalist/
I will stick with my Optical Isolation. Tera-Dak works fantastic and it did not cost me $1600 plus US.Its hilarious that adding three boxes and four power supplies would be called "minimalist".
I think he means the design of the switch is minimalist. Adding two switches and an optical bridge on our side is hardly minimalist.Its hilarious that adding three boxes and four power supplies would be called "minimalist".
I know, but he should have come up with a more appropriate title for the review.I think he means the design of the switch is minimalist. Adding two switches and an optical bridge on our side is hardly minimalist.
Minimalist refers to the design of each box via the art definition of minimalism that is defined as “extreme simplification of form and color”. He used this to contrast with the design of competitor products he referenced to which this descriptor could not be applied. That these boxes each have a minimalist design doesn’t change when someone employs several different boxes into their system because it remains true that each box “extreme simplification of form and color”.Its hilarious that adding three boxes and four power supplies would be called "minimalist".
I have one of those, cost me £20.The $1,400 Reiki switch uses the Zyxel GS-108B v3 board, in elaborate casework. English Electric, NuPrime and Silent Angel, all use that same board, sometimes with a power supply mod and/or slightly upgraded clock.
www.beatechnik.com
I have compared the EtherRegen and Pardo MiniTeddy supply vs. the Silent Angel N16 and LHY SW-10, and it beats both, in my system and in a friend's more expensive system. IMO, the ER doesn't get the respect it deserves because of its low cost and humble casework.Title says it all. If money was no object, can you name the best switch that is currently in the market and why? Thanks.
