What do you think?Im listening to this system at the moment.
When i have a good seat ill make a vid .
So so.What do you think?
Yeah, but you put out the video tease...I ve said it many times already .
If i was going all out commercially id ask manuel huber of FM acoustics for a system .
Otherwise it would be Rockport lyra kharma exquisite .
Or potentially The AG trio G3 i-tron with bass horn.
But somebody else can have a completely different opinion/ taste.
Thats why i always say go hear it for yourself , dont take somebody elses word for it .
Thanks, other than our current system, I also would say:I ve said it many times already .
Yes, it is fantastic...and if available 2nd hand probably a steal at its price.Arrakis is not commerciallly available anymore .
I ve never heard it
According to the dagostino rep. The impedance has a 2.6 ohm minimum.
Iirc.
i would try relatively low cost CAT and ARC monos on those speakers .Ok, more in line then with some previous Magico designs, it seems. No miracles in terms of low power requirements.
I can’t believe it. For such expensive speaker, they use such cheap plastic speaker binding posts.Pics
If that doesnt work a liquid power monster like gryphon apex .
I m not sure a SET could drive them.to full capacity
