im jumping the next TRUMP rallyI want one, but my kid will be jumping it through walls right now. He needs a little more self control first!![]()
For those still of the belief skinny tires are faster…
Global Cycling Network: 35 mm as fast as 26
Global Cycling Network (GCN) has been following Bicycle Quarterly and Rene Herse for a long time. Recently, they covered our Nivex derailleur in their Hot Tech review. Back in 2018, they talked about awww.renehersecycles.com
The laws of physics dedicate shimmy are faster, That presumes t rolling resistance is the dominant issue. For example, in drag racing the front wheels resemble bicycle wheels. In a drag race cornering is not an issue. The rear tire massive because of the need for traction.For those still of the belief skinny tires are faster…
Yeah, at this age and fitness I’ll take a wide, supple tire at low pressure and not need a mouthguard to protect my teeth from being rattled out of my head. I’m gonna need ‘em teeth for that tasty tasty steak I’m having post-ride.At this level of fitness and age , nothing matters or makes a difference![]()
Rolling resistance is but one factor in determining performance of the rider/bike system, and why skinny tires do not prove to be faster in real world. Else, pro riders would be still on 19mm tires.The laws of physics dedicate shimmy are faster, That presumes t rolling resistance is the dominant issue. For example, in drag racing the front wheels resemble bicycle wheels. In a drag race cornering is not an issue. The rear tire massive because of the need for traction.
For a four corner criterium a tire needs low rolling resistance and traction to provide optimum performance.
Speed is defined as how fast you can cover the course.
confirming hidh-pressure skinny tire are faster is fairly easy. I ride 23mm. Most anecdotal evidence i is wider tire provide no significant degradation in speed due to rolling resistance. However wider low-pressure tires do provide other significant advantages over a given course.Rolling resistance is but one factor in determining performance of the rider/bike system, and why skinny tires do not prove to be faster in real world. Else, pro riders would be still on 19mm tires.
Then the tests and results of the guys @ Rene Herse, and the two fellows in the video noted above, are to be dismissed? When you are faced with test results that disprove your hypothesis skinny tires are faster you ignore and only post about “confirming high pressure skinny is faster is easy“ but offer no test results to support your claim?confirming hidh-pressure skinny tire are faster is fairly easy. I ride 23mm. Most anecdotal evidence i is wider tire provide no significant degradation in speed due to rolling resistance. However wider low-pressure tires do provide other significant advantages over a given course.
My apology. Uou are tardy to this discussion. I have previously posted evidence from GNC and Rolling Resistance magazine as well as other amateurs. i have not ignored tests and field anecdotes. I concede the trend is toward lower pressure and wider tires.Then the tests and results of the guys @ Rene Herse, and the two fellows in the video noted above, are to be dismissed? When you are faced with test results that disprove your hypothesis skinny tires are faster you ignore and only post about “confirming high pressure skinny is faster is easy“ but offer no test results to support your claim?
A rational mind, when subjected to evidence that disproves a prior belief, adjusts to accommodate the new information. Dogmatic belief does the opposite.
And the key point is that rolling resistance in and of itself is not determinative of on-road results.
When you run skinny ties, you have to have them pumped up enough so that bumps in the road don't cause pinch flats. The skinnier the harder.The laws of physics dedicate shimmy are faster, That presumes t rolling resistance is the dominant issue. For example, in drag racing the front wheels resemble bicycle wheels. In a drag race cornering is not an issue. The rear tire massive because of the need for traction.
Exactly. I use a Wahoo Roam.Ralph, I think we have lreadt debated all these issues buf one. If perceived speed is yielding unreliable results, there is an easy solution. A speedometer and power meter. A Go-Pro can be used to monitor your body mechanics.
The other bit to keep in mind has nothing to do with physics, but what happens over time when you're more comfortable. That's very important when doing an ultra endurance event like the Tour Divide or Silk Road race, but it makes a difference too if you're only on the bike for a few hours. Essentially its a way to improve your endurance.Consistent with current trends I run 23 mm 60-80 psi Continental Gatorskin. I weigh 210ibs.i had a visit from the flat gods last spring. They got bored and went away. I have my eye on some Vittoria tires. Maybe I will go wild to 25mm.
