First of all, the theory: the larger the membrane, the sooner it starts to bundle the sound (scream) and there is a strong increase in sensitivity dB/watt. That was a very general statement from me. every driver behaves slightly differently has to do with the shape of the membrane(cone)
This can also be a reason why the basket on the back is strongly illuminated by the sound from the membrane and the reflection causes the increase in this frequency range in certain cases.It is effective to dampen the basket rails from the inside with a bitumen mat.
The only thing that helps is to try it out and measure the frequency response to see if it was helpful.
There are three ways to solve this error.
1. Positioning the speakers The further away they are from the 0° axis (directly aimed at the ear), the more they roll off to the high frequencies. is the cheapest solution to the problem.
2. you take an xover and filter steeply before the sound rise begins. For me it's not a good solution and usually it's to the detriment of the sound. expensive with good components
3. Use a notch or shelf filter to smooth out the frequency range to achieve natural driver rolloff. I think this is the most elegant solution. not so expensive
Why use a shelf filter? While designing a speaker using a full range driver, I ran into a common problem: the sensitivity shifts upward at a specific point making the higher frequencies output more decibels than lower frequencies. This problem is not unique to these drivers, though. Baffle step...
toidsdiyaudio.com
