ARC SP-6A Tube Preamp
maddmaxxdrummer
10
3
3
46
Montreal
Hi,
I have an SP-6A I purchased used. The previous owner says he got it from an estate sale. The unit had the electrolytics recapped about 10 yrs ago. All works well except for the MODE selector. In Stereo Reverse Mode, only the the left side outputs sound. the other thing I find odd is all the wiring was replaced with solid core twisted pair. mostly the signal wires. but also some of the power wires. The guy who did this didn't do a very good job. very messy. not twisted neatly and routed any which way. Sacrilege!. Lol..
I was thinking of redoing at least the signal cable to stock with 18 or 20 AWG 4 conductor shielded cable (color coded). This is what ARC told me was used stock. I have the schematic and its a fairly easy job except the boards have no labels. example the selector & mode switch. I could just copy the existing cable hook up, but I'm not sure if the previous did 100% correct. then I'd be copying errors. maybe that's why the stereo reverse mode only outputs one side? or maybe the switch is dirty or broken? does anyone own a SP-6A? can someone take detailed pics of the inside near the rear panel where the RCA connectors are? and the pc board where the gain, mode and selector pots are? top and bottom. this would help. i can wire some paypal money for anyone who can help me out with this.
Thx.
If you have the schematic and feel comfortable working on the equipment (which is to say you have the sense and knowledge to not zap yourself) then the thing to do is find out why one channel is out first. Obviously poking around the mode switch would be high on the list of things to check. Of course its worth cleaning the switches with a small bit of DeOxit (in the green and black can). Usually if switches are a problem they will let you know with static when you operate them.
Only after you have it running would I consider replacing any hookup wire inside. IIRC, IMO the wire they were using back then was nothing special so the wiring installed by that someone might actually be better. Its not work speculating though; get it working first.
Reactions: DasguteOhr
Hi,
Thx.
Have you looked at the ARC database?
https://www.arcdb.ws/model/SP6
There is a photo not sure if it is the view you need.
Scott
Hi, Yes, I've worked on a lot of Tube gear. That's the thing, the Mode switch isn't making any scratchy noises. all positions work correct except Stereo reverse.. right channel drops out when it should be flipping the stereo image. I will try the Deoxit fader lube(green and black) no the switch. about the wiring, the previous guys installed basic 18awg solid core wire twisted in pairs. which I've seen on lots of tube gear, but he did a poor job at twisting it uniformly and at routing it. everything is going any which way. and its the really stiff kind so un-twisting it and re-twisting it and routing it properly isn't an option. The stock wire was shielded. I believe the shield was tied at on end on run of 4 conductors.
Thx
Thx
You do have to be on the lookout for wiring errors. I agree it sucks when a rewire job isn't neat. I've done a lot of work like this- it really will be a waste of time replacing the wiring until you know why the one channel drops out. It would not surprise me at all though to find out its miswired. Good Luck and try to keep it fun.
No. if you have the gray wires in, check the continuity with an ohmmeter. Do you have all inputs aux, phono checked all the same behavior? if yes, check main output cable measure marked cable. If don't clean all the switches and then operate them very often, see if the error has gone away as Ralph recommended.20240222_203125.jpg
Reactions: Atmasphere
No. if you have the gray wires in, check the continuity with an ohmmeter. Do you have all inputs aux, phono checked all the same behavior? if yes, check main output cable measure marked cable. If don't clean all the switches and then operate them very often, see if the error has gone away as Ralph recommended.View attachment 125790
Hi, now all good. I didn’t have the grey wires. The previous owner had rewired it all with solid core 18Awg copper wire. Was a mess. Had he done it neat and all pairs twisted nicely, I would I have left it. Mind u he had some stuff wired in reverse.(left was right on some channels. I rewired the unit with multi conductor shielded cable as I was told by ARC. the original was 18Awg. I put in military spec wire. Teflon jacket. Silver plated copper. I followed the same layout as the original. Much neater now. And connected to the right inputs/outputs..
recapped all film caps with Mundorf paper in oil and Audyn MKP. the electrolytics we’re changed 10yrs ago so I left those. Got rid of all the carbon comp resistors and put in Vishay, Ohmite & KOA power resistors for the PSU. Caddock, Dale, PRP, Vishay Beyshlag , Riken & Kiwame everywhere else. I left the original 1% resistors that were there as these were all Dale military spec.
The original switches were tired and corroded. All 4 changed to Alco long shaft like the original C&K. (30$/ toggle, ouch)
The original RCA connectors were either corroded or broken inside. Swapped all 16 with Neutrik gold plated.
All pots and switches were cleaned with deoxit.
One thing i can’t figure out is the rated fuse is 0.5A 250V, but there was a 1A 250V inside. Not good. I put in the Rated fuse and it blew. This was before I did all the mods. The original owner that recapped the electrolytics didn’t use 1 for 1 values. There’s extra capacitance each bank. Example 6x 200uF was the original. He put in 6x 220uF. I’m assuming the extra capacitance is causing a current surge on start up. I installed a 60ohm 0.8A thermistor on the hot ac wire to help mitigate this. But the 0.5A still blows. But now better than before because a 0.75A was also blowing before the thermistor. now it’s not. Maybe I need to try a 0.6A thermistor to get the 0.5A not to blow on start up. I measured how high the surge is with my multi meter and it’s surpasses 1A then comes down to 360mA steady state. Will need to experiment with this. If some one has any knowledge of this. Please advise.
i might also change the tired power cord. The outer jacket is frayed in a few spots.
well anyway, it’s looking and sounding incredible.
thx everyone for your help.
Some before and after pics.
More pics…
Well done maddmaxxdrummer !! The SP-6 is certainly worth the hours and care and your craftsmanship is so much better than the previous chaps. I have recapped SP-6 twice. Both times the same unit for my best audiophile friend. One of those friends who started as a HiFi buddy and over the decades became a true friend. This friend loves his ARC. First time I worked on his SP-6 it was blowing the solid state parts in the voltage regulators. ARC advised replace the electrolytic caps along with the fried BJTs and Rs. The aging out caps increased output impedance was causing the regulator to oscillate and cause a cascade failure. When the SP-6 was in production then available high voltage electrolytic caps had a much shorter life span compared to 21st century parts. That first repair held for about 25 years than it was time to do it again. This time no fireworks, we got to it in time when it was sounding a bit noisy and just not right. New caps and it sounds great, I especially love the phono stage on the SP-6s.
One challenge restoring SP-6s is with all the versions the as built circuit on your bench may have some variations compared to the schematic. I made notes of the parts' values coming out and correlated vs. schematic to decide what to buy for the restoration. Also the 1980's circuit board does not mark parts' locations as clearly as modern PCBs. I suggest leaving the old parts in place until new parts arrive and replace one by one to avoid confusion and errors as to where a part's wire lands.
Reactions: Salectric
Hi, yes, this is an SP-6A. Yeah the phono stage sounds amazing. Although I find the phono stage level to be lower than let’s say a streaming/CD source.
Using an Audio-Technica AT-VM8 HII Moving Magnet cartridge. I don’t know specs and can’t find any online. Maybe it’s a mismatch with the phono preamp’s gain.
PC board is dated 1978.
The only schematic I found was a 1979 version. So far everything I changed and rewired all matched the schematic and with what I had in the unit.
Just need to figure out the fuse situation as I explained in my previous post.
Thx
A bit of technical babbling, got long, sorry, but may be helpful for some.
Many DIY mod folk do not realize adding a lot of decoupling (power supply) capacitance also increases the current and places stress on the power supply. In addition to blowing fuses, regulators (SS or tube), wiring and PCB traces, switches, and such all see higher current. This can cause failures both fast (short-term, e.g. blown fuse) and long term (e.g. PCB traces gradually deteriorating, transformers failing).
Older capacitors lose capacitance for several reasons. Their electrolyte, the film inside the capacitor that separates the metal plates (foil, film), can dry out and become a worse dielectric. This both decreases capacitance and increases likelihood of the voltage causing brief shorts that usually burn holes in the conducting film, pin-holes. The holes decrease capacitance, and "junk" around the holes like metal film shards and "goo" provides conduction paths that increase leakage current. That in turn heats up the capacitors, which causes more failures, and so on. Old capacitors thus lose capacitance (the ability to store charge) and increase leakage (causing greater current draw to ground instead of going on to the circuit being powered). Note new capacitors, especially electrolytic types commonly used in power supplies, usually measure about 20% high in capacitance value so they still meet spec (which is often 50% of their rated value) at end of life (varies by capacitor, may be 10,000 hours or more of use).
Another consideration is the internal resistance of the capacitor, equivalent series resistance, ESR. New capacitors may have lower ESR than old capacitors since the conducting film is new, may be thicker by design (to lower the ESR), and that will also increase the inrush current since lower ESR means more current can flow more quickly. Sometimes moderate ESR capacitors are specified to both the limit current and reduce "ringing" on the power rails due to capacitors interacting with inductors like transformers. Choosing the absolutely lowest ESR capacitor may not always be the right choice when replacing capacitors.
The inrush current, the current surge at turn-on, for an ideal capacitor is i = C* dV/dt, the capacitance C times the change in voltage dV divided by the time for the change dt. The change in voltage is usually from 0 V (off) to the full supply voltage when on. Increasing the capacitance thus directly increases the current, since the final supply voltage is unchanged. Adding a resistor (thermistor) increases the time to charge, dt, and depending upon the load also reduces the voltage (until the thermistor heats up so its resistance become near 0 ohms), thus reducing the current. ARC and other manufacturers would sometimes use a series resistor to reduce inrush current. The resistor was often in the incoming AC (wall power) circuit, and a relay would short the resistor after a short pause to allow the capacitors to charge more slowly (thus reducing inrush current).
Determining the peak inrush current usually requires a broadband current sensor, for example a special oscilloscope probe, to capture the peak and slew rate. A broadband current meter may also be used, though these are not usually your average household meters. Since current sensors are not common (and expensive), I'd guess more often a small resistor (say 1 ohm or less) is added to the line and the voltage across it measured by the 'scope to determine the peak current as i = V/R where V is the voltage across the resistor R (Ohm's Law).
To determine the fuse's value, you add some margin on top of that peak current, as running up to the current rating every time you turn on the device will eventually blow the fuse. You (the designer) must also ensure the rest of the supply, wiring/traces, transformer, regulator devices, etc., can handle the surge current without damage. This all means giving a simple answer is not really possible without a lot more information, some of which likely only ARC knows. You can look up ratings of the series-pass regulator devices (derating of 20~50 percent is common) as a start, but you might want to just ask ARC and see what they say. In the past they were pretty helpful when I was repairing gear, but I have not done that sort of work in years and have no idea their policy now.
Given the circumstances, and knowing the fuse is there to blow in the event of catastrophic failure, I'd probably throw in a 0.8 or 1 A fuse and hope it lasts the life of the preamp. That is a pretty loose guess, and no doubt others (like me) would want to dig a lot deeper into why the fuse is blowing, and either fix the reason or more thoroughly understand why the higher rating is needed along with ensuring the rest of the supply is OK with the higher surge. I have no idea what equipment you have and your knowledge base to analyze this.
FWIWFM - Don
Maybe new caps have so much low ESR that you get high charging current peaks. The thermistor is a good choice, but remember if it is still hot it doesn't have a function, always let it cool down before switch back On then the fuse should no longer trip. Good work
FWIWFM - Don
Hi, I’m not that technical. I don’t really have test equipment other than Variac, multimeter, tube tester. Each electrolytic has 20-30uf more than the original and so I’m thinking this is the cause of the fuse blowing. But when I asked ARC. They didn’t think so… weird. With a 60 ohm 800mA thermistor I managed to get a 750mA fuse not to blow. I would like to get the rated 500mA fuse not to blow. This is what I don’t know how to do. Select the thermistor for the 500mA not to blow. I will try to get a max current reading on power on and take from there
I doubt an extra 10~20% in capacitance is enough, may be something else going on. Without tools and techie knowledge it may be hard to figure out the root cause; it may be a combination of things. Could even be tubes drawing a little more current that, added to everything else, is just enough to blow the fuse. If the SP-6 uses a string of zener diodes in the power supply regulator, those could have decreased resistance over time and increase the surge current. Etc. At this point, short of sending it to ARC or a good tech, you are left with trial and error. The problem is clearly inrush current, so I'd probably get a 100~120 ohm thermistor and if that worked with a 0.5~0.8 A fuse call it done.
Reactions: maddmaxxdrummer
220uf is the value you're going to find these days and should be no worries.
But they need to 'forum up' (they draw a bit more current at startup otherwise; so this will take about 200 hours for them to settle in) and you also should be using a slow blow fuse. If fast blow it will likely vaporize as soon as you try to turn it on.
Hi, the electrolytics were recapped 10yrs ago not by me. And it’s not just 1 cap of 220uF. It’s 6x 220uF instead of 6x 200uF. Plus the other caps, 2x 100uF instead of 2x 75uF, 2x 330uF instead of 2x 300uF. All the Extra capacitance must be causing current spike on start up.
That will be especially true if the preamp has sat for a while- the caps may have lost their 'form'.
