Hi mtemur, I agree! While I am a fan of linear trackers, I also worry about these pivoted linear trackers having too many bearings.
At @Mike Lavigne the field coil primary control unipivot - which uses the field coil to make the arm more stable - was good on bass, there was no lightness. But Mike is better positioned to compare how the bass is to his previous DurandDear @thekong rigidity of a tonearm is really important from my point of view especially the bearing rigidity. I always feel that unipivots lose bass information while adding extra to highs.
To achieve the goal of linear tracking, the Schroeder LT and Reed 5A surely employ more bearings than a normal pivotal arm. Whether that is too many bearing is hard to say, as it depends on the compromise the designer and users are willing to take!does the Schroeder LT have too many bearings? I have heard it three times sound sonically good, including in one direct compare with the older SAT.
mtemur your technical knowledge will be appreciated in the investigation
Schroeder LT is a tangential tracker according to the info and pictures I saw on the web. It has to have a mechanism similar to Reed 5A but magnets might be used instead of rods. I heard this tonearm at Munich while Ana Mighty people were doing the presentation. I remember I was impressed more by the precisely set cartridge compared to sound.does the Schroeder LT have too many bearings? I have heard it three times sound sonically good, including in one direct compare with the older SAT.
I only listened to AF10 tonearm a few times in Munich and in Tokyo. Having not be able to compare AF10 with other arms side by side I can't tell the difference in sonic character of it with other arms. The closest that I got was in Tokyo, upon request, they A/B compared AF1P with AF10 arm and AF3P with Graham Elite arm. The difference was obvious. AF1P/AF10 combo was a lot better.Dear @thekong rigidity of a tonearm is really important from my point of view especially the bearing rigidity. I always feel that unipivots lose bass information while adding extra to highs. I noticed evidence to this when a high priced unipivot could not track low frequency sweep while a cheaper ball bearing arm could track perfectly (same cartridge used). You may think how it’s all related with ViV. ViV or other arm depending on a bearing floating on liquid isn’t rigid enough in my book, not even close to unipivots let alone better more rigid ones.
Last November I had a pleasure of spending quite some time with TechDas AF10 air bearing tonearm in Tokyo. It was incredibly detailed, high resolution, resolving tonearm. It was like 192K 24bit while other arms sounding like mp3. I never heard any other arm reaching that level of resolution while being fatigue free. But I’m not sure about the bass, the base of sound didn’t seem right. Air bearing might be making arm friction free and enabling cartridge to read more information carved in the grooves but at the same time disconnecting the arm from the base. I still prefer SAT, AS Axiom or even Kuzma Safir because of their grounded sound. I don’t know maybe I’m wrong. IMHO @TLi can do better judgement since he has SAT and familiar to AF10.
Audio Tekne says this same thing. Not only the rigidity of the wand but the entire tonearm structure. Wide bearing, no adjustments on the arm other than one counterweight. I was worried about not having any adjustments but clearly I was wrong.Many designers and users concentrated the discussion on tracking error and think this is the more important factor that determines the sound quality. I found it is not true. The rigidity of the wand is the most important property. The control of resonance in the wand contributes significantly to the performance.
My question to you is unanswered too. Did you hear tracking error and distortion when listening to ViV? I’m not talking about hooking your software up to it.If there is no difference in direct comparison to "normal" tonearms and differences between stylus profiles can be heard "ALWAYS the same" why would I or anyone choose ViV? What's the benefit of ViV when everything is the same like other tonearms?
My original question stays unanswered so, I ask again.
You don't have to follow the rules but what's the benefit, where is the gain? Regarding the design of ViV arms what's the benefit of:
- Omitting overhang and offset when underhang introduces higher tracking error and distortion?
- Omitting anti-skating when skating force also applies to underhung ViV arms and additionally changes it’s direction in the middle?
Sorry, I missed your question. Quick answer is yes, you can definitely hear tracking error and tracking distortion. I remember hearing ViV in Munich but not impressed if I’m not mistaken. In shows it’s hard to pick the equipment responsible for the final sound.My question to you is unanswered too. Did you hear tracking error and distortion when listening to ViV? I’m not talking about hooking your software up to it.
Yes, probably impossible to pick out the arm in a system you have no experience with. I don’t think anyone is going to argue and say precisely aligning a cartridge is a bad thing. I have definitely experienced what you describe with typical arms. However, for me, ViV is doing something different which supersedes the standard rules. As soon as I put it in it was clearly obvious it was better to me than typical arms I’ve used in the past. I was mostly using conical cartridges with my ViV. Now I use a different arm which also does not follow any standard geometry or even allow for any adjustments and the sound is like nothing I’ve heard before.Sorry, I missed your question. Quick answer is yes, you can definitely hear tracking error and tracking distortion. I remember hearing ViV in Munich but not impressed if I’m not mistaken. In shows it’s hard to pick the equipment responsible for the final sound.
If you can precisely align zenith angle you notice how everything becomes settled, precise. When zenith angle is wrong sound becomes congested and rushed. It feels as if it becomes a little bit more detailed because of increased distortion and a little bit smooth because of reduced dynamism. You notice how everything becomes precise and focused only after you aligned zenith back to precision. Precisely aligned zenith is not just aligning cantilever to the line on protractor. I tried fiddling with zenith alignment many times and always heard a great improvement on sound. Other members can explain their experiences with zenith better than me. You may say what’s zenith got to do with tracking error. Zenith is directly related with tracking error, when it’s not aligned precisely the tracking error increases. ViV is ruining zenith by it’s approach.
Now, I’m not asking directly to you @djsina2 but I wonder will I get logical answers to my questions or I should rely on the prior comment that ViV is magical?
I’m glad they worked for you.Yes, probably impossible to pick out the arm in a system you have no experience with. I don’t think anyone is going to argue and say precisely aligning a cartridge is a bad thing. I have definitely experienced what you describe with typical arms. However, for me, ViV is doing something different which supersedes the standard rules. As soon as I put it in it was clearly obvious it was better to me than typical arms I’ve used in the past. I was mostly using conical cartridges with my ViV. Now I use a different arm which also does not follow any standard geometry or even allow for any adjustments and the sound is like nothing I’ve heard before.
Likely would tell you nothing since your other arm structure is nothing like the ViV. The arms are so cheap, why not try one?I'm continuing to try to understand why those who try the VivLabs arm report so positively, when the logical arguments would suggest otherwise. I did come across a thread elsewhere that attributes the effect to the scrubbing motion of the stylus when the cantilever moves horizontally or vertically. The reasoning appears sound and the linked videos recording the output certainly show a difference (I'd suggest watching/listening before you see the two tonearms used!)
I have several tonearm pods that are currently unused, which would allow me to position an arm so the stylus is underhung, and it would be trivial to drill one hole in an SME 309 headshell (I have plenty) to mount a cartridge without offset. I'm tempted to find out for myself when the appalling hot weather is gone and I can fire up the tubes.
