Yes it lacks a symmetrical array to control the radiation pattern, therefore your setup is quite different from a D’Appolito configuration.lacks 2 midbasshorns above HF, but line source from 65 and up....
and "electronic pointsource" from 65 and up
A D'Appolito array is a specific configuration of drivers. All we are saying is that your speaker system is not a D'Appolito array, and it is not similar to a D'Appolito array.it has control of radiation pattern, but in a different way
Yes, they do sound better from YouTube directly.Make sure that you are listening to the video on the YouTube App or on the YouTube page in a separate window tab and not on WBF. It makes a difference.
It is totally okay that your speaker system is not a D'Appolito array.![]()
Totally different acoustic centers vs D’Appolito . Take one of the lower horn woofers and place on top of your Hi frequency horn and Bob’s your uncle ...!
Regards
Technically, a true D’Appolito also uses a third order crossover as the crossover type affects the lobbing tilt.A D'Appolito array is a specific configuration of drivers. All we are saying is that your speaker system is not a D'Appolito array, and it is not similar to a D'Appolito array.
Perfect D'appolito is almost impossible if the distance between the drivers is too large. acoustic energy speakers do this excellently.listen to this then you know how good it sounds.Correct. In addition to the Midrange-Tweeter-Midrange drivers’ arrangement, there are driver center-to-center spacing requirements to address lobe tilting and to maintain a point source polar radiation, typically a 1/4 of the lowest frequency’s wavelength center-to-center spacing.
Hi Greg,Saw the video. Helmholtz Resonator?
The original design by Joe D’Appolito was with 3rd order crossovers, I discussed it with him in person back when he was designing for Usher loudspeakers.Not always Morri , many designs used 1st and second order , Dunleavy for eg used 1st order slopes , excellent step responses..
Not Sure what Peter at PBN using on his Horns ..
Regards
'Nother 2A3 Luv vocal on 75 inch ribbons to despoil the thread. Live is more dynamic, and I can hear his breath sounds moving around the microphone, which I can't hear on the vid (at least I can't).
75 inch BG Wisdom Audio ribbons, kin and kith of the Pendragon ribbons I would presume.What Ribbon is this..?
Your experience surpasses mine.Here is my logic, with over 37 years in this hobby, I now have roughly 47 systems at home with some of the world’s best components, expanding all topologies and factions of this hobby, which give me first hand experience to just about every type of system here at home. Add to this, I have literally traveled all over the world which has allowed me to listen to the latest, greatest, most expensive, and highest regarded systems and components in dedicated rooms at both dealers and end-users optimized settings. My in-depth understanding of the recording, mixing, and mastering processes allows me to have expectations of what can be achieved not only in playback but more importantly in the realm of technologies available to optimize the retrieval of nuance and inner detail. And last but not least there is my technical background in physics, electrical engineering, and acoustics which allows me to understand the elements at work in sound reproduction. I have an extreme understanding of electronics design and mastering techniques and those allow me to analyze system videos for the relevant information required to make assessments and drive corrective action, when needed. That’s my logic. What is yours?
Thanks Bonzo I will check that thread. I am relatively new and this forum has an incredible amount of information and opinion.A lot, but it has been covered for last 5 years in the acoustically video coupled thread, which “summarises” similar discussions across many threads. I am happy to continue that discussion here or on Al’s system thread because both these thread owners owe us that space.
