Why Run More Than One Tonearm?
Tangram
507
629
170
62
I’m considering adding a second tonearm and cartridge to my turntable in the New Year. But if I am honest with myself, I’m not really sure I need one! I listen to rock and jazz, and have only a handful of mono recordings. Yet, many WBF members who are into analogue often run two or three tonearms on a ‘table. I’m curious about the reasons why.
I used to have a turntable that could support only one tonearm. I designed an outboard arm pod so I could add a different second arm. I had two different cartridges and I enjoyed experimenting with different combinations for slightly different presentations.
I then bought a turntable that supported two arms. I bought identical tonearms and used different cartridges for slightly different presentations.
I now have a turntable that supports four tonearms, but I only use two. They are the same tonearm and I have multiple copies of two different cartridges. Right now I am experimenting with two identical arms and two identical cartridges and I will set them up for different thickness records. One will be set up for thin vinyl and one for thick vinyl.
It is also nice just to have a spare combination in case something breaks and needs to be repaired. I think most people do it because they enjoy experimenting with different sounds and for stereo and mono cartridges or moving magnet and moving coil.
My table can accommodate two arms but in practice I only have one mounted at a time. Two reasons: First, in my experience the presence of a second arm, when mounted directly on the aluminum table base, has an adverse effect on the sound of the first arm. Second, it is awkward to align the second arm and awkward to use the curing lever.
Bottom line for me: one arm at a time.
I think the main reason is that it allows you to have 2 cartridges available to you at any time. I am not saying you need to do that but if you are interested in that flexibility it is more convenient than having 1 tonearm and swapping cartridges and aligning them every time you want to change.
Reactions: Johan K and PeterA
I have two turntables, plus four Acoustand tonearm pods. Currently using just two of the pods, so I can have four SME tonearms (IV x2, V x1, 309 x 1) on two SME turntables. Why?
Well: my best stereo cartridge is a BM LP-S, but it's only just a tiny bit better than the London Decca Reference. Then there's the BM Ruby 3 converted to mono (by Steve Leung) for mono LPs, and the Nagaoka MP-500, which is good in its own right, but also it the one I use to play disks for the first time in case there is some fault that could tear the stylus off. I'd rather replace a stylus than send an MC off for a re-tip. The tonearm pods are all on sharp spikes, and weigh 10lb each: a good cartridge mounted on an arm on one sounds better than a poor cartridge mounted on the built in arm. The VTA adjustments of the pods are far easier than the native SME adjustments, and can be changed during play, if that's your thing (not mine: set and forget is me).
I could simply play everything on the LP-S, but this way I get some variety and make the styli last longer, along with the super quiet mono playback from a true mono cartridge. I'm happy.
Well: my best stereo cartridge is a BM LP-S, but it's only just a tiny bit better than the London Decca Reference. Then there's the BM Ruby 3 converted to mono (by Steve Leung) for mono LPs, and the Nagaoka MP-500, which is good in its own right, but also it the one I use to play disks for the first time in case there is some fault that could tear the stylus off. I'd rather replace a stylus than send an MC off for a re-tip. The tonearm pods are all on sharp spikes, and weigh 10kg each: a good cartridge mounted on an arm on one sounds better than a poor cartridge mounted on the built in arm. The VTA adjustments of the pods are far easier than the native SME adjustments, and can be changed during play, if that's your thing (not mine: set and forget is me).
A picture would be nice ! :)
Reactions: Johan K and XV-1
My main reason for two was to incorporate a mono and Stereo cartridge.
As far as I am concerned, it would be to save time. Time removing and setting up another cartridge, then setting the phonopreamp after that.
Some people just enjoy the presentations of different cartridges and I am one of these people.
Some people have dedicated mono carts/arms and some people dedicated MM carts/arms. That is not that uncommon either.
Best thing I did for my vinyl end was to get two tables. I can switch sources on even the same album if I wanted.
I modified one side today as an experiment: I placed one of the unused pods under the distal end of the tonearm panel, just for more stability and mass:
Perhaps I should ask Lee if he can make an extra long tonearm panel with a second attachment point at the distal end, so it can be screwed into the second pod. This would leave the arm mounted on a panel affixed at both ends to a 10lb pod. Not visible in this photo is a Series V on the built in tonearm mount with the LP-s on it. The other table is set up similarly.
there is a GAS (gear acquisition syndrome) aspect to multiple arms and multiple turntables; and multiple cartridges and phono stages.....for sure. this is not about need.
yet; I think for me the stronger thing is simply it's enjoyable, and musically interesting, to play music on various turntables, arms and cartridges and phono stages. it's a deeper dive into how vinyl works, and the result. it adds to the satisfaction of many sessions. other times I just choose one.....which is good too. sometimes "multiples" allows a finer level of tune as each combo pushes the other ones to stay at their best.
could I step back into a single tt, arm, cart and phono? I can see that happening after I get this phase of the hobby out of my system. but I have no idea when that might happen. maybe my kids will have to figure it out.
I have 2 tts that can acommodate 4 arms each
presently I have 8 arms, 6 installed
Airtangent Reference is in UK for repair
no single combo is best in all aspects
Melco: Eugene Komissarov Supertracker, IKEDA IT 407/The Peak/The Groovemaster
MS DDX 1500: Dynavector DV505/Kiseki Gold and an Alfred Bokrand presently on service
The Peak is set up with dedicated DaVA mono cart and SUT combo
the rest are different cart/arm/armcable/SUT combos
MS DDX1500 also covers 45rpm LPs
My turntable is designed for 2 tonearms, but I chose to have only one tonearm. Like you Tangram, I only have a handful of mono records so I don’t see the point in a second tonearm / cartridge. I would rather spend the extra money on other needed parts of the system or get more records.
I like the “get more records” part!
Reactions: Johan K
You really should listen to a mono record with a mono cartridge: My experience will not be like yours, as I have only one functional ear and never hear stereo. But a mono record through a stereo cartridge has more surface noise than though a mono cartridge, no question.
And with respect to my post above, Lee Drage is going to make me a couple of tonearm panels that will bridge the two pods. He seemed to imply he could make each hold two tonearms, but that, says my esprit d'escalier, would be a bridge too far.
Reactions: Johan K
If you have mono records a mono cartridge on a second arm can make sense but I not necessary IMHO. On the other hand if you have a collection of double 45rpm records then second tonearm makes perfect sense. Cartridge alignment changes dramatically between 33.3 and 45rpm.
78’s
Reactions: bonzo75 and Johan K
Mtemur, Could you please explain why cartridge alignment changes between 33.3 and 45 rpm? I figure there are more dynamic forces in play, so more pulling on the stylus changes SRA angle and horizontal alignment, possibly even skating force, but I would think only slightly. Are these the reasons and is it audible? Thank you.
I’m considering adding a second tonearm and cartridge to my turntable in the New Year. . . . Yet, many WBF members who are into analogue often run two or three tonearms on a ‘table. I’m curious about the reasons why.
I was somewhat ambivalent about having two cartridge/tonearm combinations. I understand the idea of wanting two "flavors," but I've seen some people make the mistake of having two cartridge/tonearm combinations that sound so different, they wind up listening most of the time to only one of them.
So I was determined to pick two "flavors" I know I like – – chocolate and vanilla – – as opposed to, say, chocolate and pralines with spice cookies.
I am very curious which of my two cartridge/cartridge combinations I will end up listening to the most.
If I wind up listening almost entirely to one of the combinations, I would sell the other combination.
Reactions: Tangram
