Interesting! Thank you!The panels are currently absorbing sound at certain ratios over a moderate frequency range then reflecting the remainder so those reflected fr will be causing smear with the direct sound .. this will direct at least any higher fr away from your listening spot ... and hopefully more clarity and more solid sound stage .. if you partially overlay them .. tuck one in say half distance or so behind the other it should be more effective lower down ... anyway that's the theory![]()
I have no way to keep them standing up straight at that angle, however.
