Hi Ron,Welcome to WBF!
Congratulations, Michael, on getting Bionors!
Can you tell us about your listening room and your audio components, please?
thank you very much for your kind words and your welcome... I use the Bionors at the moment in my office, the room is large, around 50 square meter with circa 3,40 meter room height...
To drive the Bionors there are two audio chains there: A Garrard 301 with grease bearing and Ortofon RF-309 tonearm with SPU A, Jorgen Schou step-up transformers, Shindo Mazeris Bellevus preamp and Shindo Palmer power amps with Western Electric VT-52 DHT's or two Telefunken V69 power amps, push-pull class A with F211a power tubes, driven by a Topping E50 DAC for streaming...
At home there are several audio chains, in my listening room mainly JBL 4350 studio monitors, biamped with EAR 509 and 549 power amps, Audio Research active tube crossover, EAR 912 preamp and EMT R80, Garrard 301 or Thorens TD-124 turntables, a second chain with JBL Olympus, driven bei La Maison de L'Audiophile 300B power amps etc... In the living room I use JBL DD-66000 Everest with Sun Audio 300B parallel single ended monos (all Tamura iron) or McIntosh MC-3500 power amps from the sixties if I need more power, preamp and DAC is an AMR DP-777, phono pre is AMR PH-77, turntables La Platine Verdier, Micro RX-5000 with FR-66S and EMT 927... In the dining room resides the JBL Paragon with period correct amplification, McIntosh MC-75 power amps, C-22, MR-71 and Luxman PD-444... In the small library are Yamaha NS-1000M with Yamaha B-2, C-2, T-2 an Luxman PD-310...
All together too much audio gear, especially turntables, the future will be reduction and concentration on the essential...
Best regards
