With close to sixty square feet of radiating surface, front and back, the 20Rs can move air, and, since they do radiate front and back, they move that air through an angle of virtually 360 degrees-just like musical instruments do. When you couple a very large radiating surface and virtual 360-degree dispersion with unenclosed, nearly massless drivers of extraordinary speed and integrity, you end up with one of the most naturally-sized soundfield, peopled with the most naturally-sized and naturally-detailed instruments, you'll ever hear.
It's not just that instruments are realistically larger, or the soundstage broader, deeper, and higher, than what you usually get through even a very good hi-fi system; it's that everything within the soundfield moves air in more realistic proportions. Through the 20Rs, a bass drum isn't a compact little item at the back of the stage, imaged with laser-like definition and reproduced with the sharp percussive crack of a handclap, but a huge hollow-bodied instrument that, when struck hard, sends forth waves like a dam bursting on a valley town. Through the Maggies, that drum'll make you jump, all right, but not because the speakers "go so deep" (although the 20Rs definitely do-flat to 25 Hz in my room), or "image so tightly," or have "lightning-like transient response." None of that covers what I'm talking about. That drum'll make you jump because it sounds more like a bass drum, because the physical size and shape of the instrument and the sheer volume of air it moves when struck hard are being reproduced with greater verisimilitude.
I hate to beat this poor dead horse again, but, in life, no instrument is the sonic equivalent of a wallet-sized snapshot-a sharp little image neatly tucked beside other sharp little images. It's a big, supple, three-dimensional thing that changes dramatically in shape, color, size, and impact with changes in the way it is being played. The very idea of trying to "reproduce" a grand piano (or a triangle, for that matter) realistically through your average-sized box speaker is laughable. It's like watching Lawrence of Arabia on a thirteen-inch Samsung.
http://www.magnepan.com/review_MG201_Best_Buy_Part_III
I suppose then this will do little to settle anything in this thread. There are countless accounts of imaging similar to this. But it is nit ignorance to these claims that fuels this argument. In fact it is these very clams that have stirred the detractors. It is rather the general disdain for audiophile terminology and perceptions that have stoked the fires of their disbelief. Unfortunately that will detract audiophiles from the real discussions
