BAYZ Audio UK Distributor is Hifiguy https://hifiguy.co.uk/No, but I'd like to. Sadly I don't think there's a UK distributor and the bigger ones are probably beyond my budget.
No, not quite there yet, but these last few years I've been focussing more on getting the basic, physical outlines of a speaker system in place; as in prodigious displacement area top to bottom, high efficiency, relatively unrestricted frequency range (i.e.: honest ~20-18kHz) with full tilt capabilities in the lower range as well, outboard active configuration with digital XO/DSP, plenty of headroom for any SPL requirement, fairly uniform dispersion patterns at the crossovers, proper physical height of the main speakers, etc. What I do have now achieves mentioned parameters rather well though, and the way they've been implemented so far I'm enjoying their sound very much. Indeed whatever sonic limitations there are has less to do with my current speaker setup than how it's implemented.Do you consider your loudspeaker perfect for your personal sonic preferences and perfect for your ears?
Yes. Speakers are a potential only, and getting all the intertwined parameters in place here in conjunction with the acoustics, electronics and one's ears is not an easy task. It seems though that technology in the shape of digital tools are coming more and more to our aid, although I'd caution against their over-use so not to place too heavy a burden digitally of what should have been done more predominantly physically and acoustically in the first place.Do you believe that loudspeakers are the most difficult or "problematic" category of components?
Approximating the "perfect" speaker, as I see it, is with the outset of a proper physical framework of a speaker that's in further need of careful implementation acoustically, electronically and to our ears. Buying pre-configured, passive speakers believing they're perfect in themselves would depend on a plethora of factors falling into place, that hardly can.Do you believe there is such a thing as the "perfect" loudspeaker for you personally? Or is some compromise, large or small, inevitably part of the equation of every loudspeaker. (A "compromise" could be in size of loudspeaker or drive requirements or frequency balance or dynamics or transparency or any of the sonic characteristics we ever talk about.)
How would you apply these questions to your current loudspeaker?
I look forward to watching you build this...I am not sure if you have set up a thread for this...but would definitely read it if you do/did.No, not quite there yet, but these last few years I've been focussing more on getting the basic, physical outlines of a speaker system in place; as in prodigious displacement area top to bottom, high efficiency, relatively unrestricted frequency range (i.e.: honest ~20-18kHz) with full tilt capabilities in the lower range as well, outboard active configuration with digital XO/DSP, plenty of headroom for any SPL requirement, fairly uniform dispersion patterns at the crossovers, proper physical height of the main speakers, etc. What I do have now achieves mentioned parameters rather well though, and the way they've been implemented so far I'm enjoying their sound very much. Indeed whatever sonic limitations there are has less to do with my current speaker setup than how it's implemented.
What continues now therefore is a further refinement from that physical framework, and that could involve a restructuring to digital amplification for a simpler hardware implementation and overall signal path (with a digital source only), while also incorporating a FIR-based (IIR filtration presently) digital crossover as well as digital room correction in both the amplitude and time domain down the line - when the technology has matured just a wee bit more. Also a few replacements in the speaker system could be implemented eventually, such as - possibly - a horn-loaded midbass to lower midrange section and a likely Synergy horn on top. My tapped horn subs should remain in place.
Whatever hardware is intended to be replaced must be made "making sense of the madness," as they say.
No build thread yet, but I guess such could surface eventually. As I said, the basic setup framework I got already, and it's very satisfying as is. I'm sure many an audiophile would scoff at industrial looking, actively configured cinema speakers, studio amps and behemoth sized tapped horn subs (i.e.: 20 cubic feet per cab), but to mind and ears there IS actually some sense to the madness here.I look forward to watching you build this...I am not sure if you have set up a thread for this...but would definitely read it if you do/did.
Thank you. Actually, I dont think it's crazy at all. In fact, it looks extremely practical...high sensitivity, a very efficient footprint...takes advantage of the height in a room to create more cubic volume and presumably more air displacement with dual-large-cones and a very large horn.No build thread yet, but I guess such could surface eventually. As I said, the basic setup framework I got already, and it's very satisfying as is. I'm sure many an audiophile would scoff at industrial looking, actively configured cinema speakers, studio amps and behemoth sized tapped horn subs (i.e.: 20 cubic feet per cab), but to mind and ears there IS actually some sense to the madness here.
I’m using a single JTR-S1 18in sub in my system and it works very good in my system. We had it calibrated using REW and it’s a seamless transition between my mains and the JTR. I have considered getting another one but after the calibration it disappears and can get down to gut wrenching lows.Thank you. We enjoy it, and are currently now looking at the subwoofer element where we are thinking of something all-out to create a greater, more solid foundational element to the music. As the Wilson-designed Subsonics effectively focus on sub 32hz (rather than the REL 6-pack 32hz, then 42hz, then 52hz for 3 different levels of the 6-pack)...starting to consider either a pair of dual-opposing 18" (1 for each speaker) or a single dual-opposing 24" which has greater, more effortless air displacement and optimized performance for sub-40hz.
Yes. YG Sonja XV2 with Boulder 3060 amp, Wireworld Platinum Eclipse 8 speaker cables. Great for hours and hours, never any fatigue yet amazing clarity and power, with any musicDo you consider your loudspeaker perfect for your personal sonic preferences and perfect for your ears?
A word of caution regarding ATC 50 Actives. These are designed specifically for pro studio use and not for domestic listening, despite some versions having aesthetically improved enclosures compared with the standard studio version.few days ago I could listen to a pair of ATC SCM 50’s and boy can they play neutral, loud and undistorted totally different from my KLIPSCH.
I have been listening to a pair of Legato Unum SE speakers and I must admit they are pretty awesome. I had never been a big fan of 2 way speakers in the past. These have changed my mind.For my current listening environment and synergy with my component selections I am a yes. My Sonner Legato Unum’s are perfect. And if I take on a larger room in my home (empty nesters second floor is not used) I will just get the Legato Duo‘s, simple.
I understand what you r saying but on the other hand, I don’t.A word of caution regarding ATC 50 Actives. These are designed specifically for pro studio use and not for domestic listening, despite some versions having aesthetically improved enclosures compared with the standard studio version.
I'd be hankering for a pair of these speakers for years and when some came up (directly from ATC), I bought them. However at home they were far too "in-yer-face" for comfortable listening, Accuracy is not necessarily the most important feature of good domestic speakers, though essential in the studio.
they are perhaps to technical, cold and not emotional..... ?I understand what you r saying but on the other hand, I don’t.
I thought audiophiles wanted to hear as much into the recording as possible ? so ATC must be one of the better speakers out there? Relative flat frequency response, they don’t distort at higher SPL, very detailed. So if the mixer and mastering engineer did their job, what’s not to like ?
Not everyone would agree on ATC speakers being a bad fit in a domestic setting. I've heard ATC's in different iterations, rooms and systems - active, passive and different sizes/models - and it goes without saying they're not only very revealing of the source material, but as well the source components (digital or analogue) and preamp implementation (and power amps, if passive).A word of caution regarding ATC 50 Actives. These are designed specifically for pro studio use and not for domestic listening, despite some versions having aesthetically improved enclosures compared with the standard studio version.
