After inserting the Aardvark isolator last Thursday approximately 70 hours have passed. And even though this isolator is not yet fully burned in - according to Eduardo it needs at least an additional 100 hours after the 50-60 hours of playing in at his place - it is already quite clear what it is doing: removing distortion/noise. This results in my LA set up in more transparency and openness, better dynamics and a deeper soundstage.
However, initially one aspect was not to my liking: the tonality was ‘sharper’ (or ‘fresher’ if you will) than I had experienced before. When I inserted the Aardvark isolator I was not grounding my Kondo g-1000 preamp and my Kondo Gakuoh poweramps. Why not? Because I currently do not have three extra top notch Tripoint Audio cables available. As mentioned earlier Miguel is at the moment working on my Emperor NG ‘grounding’ unit and six new Tripoint Audio cables, three of which are the very special - and only made on special request due to the material cost and intense labor time involved - Emperor NG grounding cables.
It occurred to me that the possible (or even likely?) explanation for this ‘sharpness’ or ‘freshness’ is the following: the Aardvark isolator lowers the noisefloor in such a way that the inherent distortion/noise produced by my Kondo (pre)amps is being laid bare more clearly than in the past. In order to test this hypothesis I disconnected three Tripoint silver signature grounding cables (Tripoint’s entry grounding cables) from their three copper platforms and connected them to my Kondo (pre)amps. This remedied to a significant extent the ‘sharpness’ of ‘freshness’ issue.
I am sure that once I have inserted the six new Tripoint Audio grounding cables (but that will take a while because Miguel will finish and ship the Emperor NG ‘grounding’ unit first to me) the afore mentioned ‘issue’ will be solved completely. But hopefully additional playing with the Aardvark isolator will in the meantime help as well.
