Correct. If you run them in mono where the amp requires you to use the left channel speaker output and you want to compare it to stereo mode using 1 channel, all you need to do is change the back switch from stereo to BTL (mono). Just make sure you turn off the amp first.@sbo6 to be clear (to me), your preference with the m900s was: run both amps in stereo, with left output from one amp to left speaker, and right output of one amp to right speaker? Hmmm. Have not tried that. And no downsides? Cheers...
Also, FWIW, in my system, I noticed no difference in dynamics in mono vs. 1 channel per amp stereo.
