Or Kuzma? Or Brinkmann? Or Bergmann?
Not expensive enough, Shane clearly mentioned "expensive" TTs.
Resolution also meaning transparency, tonal balance, etc complicates it entirely and becomes a bucket term for everything. It can be used as a shortcut...this system had higher resolution across the board...and left at that, or you can get into more detail. Anyway when we write in more detail we clearly start with spelling out things at a higher level (as simple as this was my preferred component), then get into more detail, write about weaknesses on the lesser liked component (e.g. that lacked weight), and further use cello, violin, orchestra, etc descriptions to further clarify. The committed ones further use videos to add to the words.
Therefore, after all this, just using resolution as a blanket term to me makes no more sense than simply saying I preferred A over B on all aspects. While valid, it reduces detail and transparency in the whole description process. Unless a video showing the differences is added, as that reduces the need for verbosity.
Resolution as a word has a clear definition as it should be used in Audio:If we all said I like this better and that not, there won't be much conversation and a need for a forum. Same with sports. This guy won us the match, that guy didn't. We analyse stats, discuss nuances of the game, some objective, some subjective.
I am interested in communicating in a way the reader intuitively understands what I am saying...where this is not possible some explanation is required to make him understand easily.
I pretty much agree with this. I find more value in moderately detailed descriptions of what is heard rather than "more of this audiophile attribute, less of that." There's almost no agreement here on what words like "resolution" mean. People throw around "resolution" and "transparency" as if they are commonly understood terms with clear and distinct definitions, then add modifying adjectives on top of those. Rather than putting sound in audiophile boxes, tell us what you hear.
partially agree. Transparency default meaning is the see throughness while playing a track the kind best demonstrated by electrostats. So I feel I have to qualify transparency to recordings.
resolution default is detail, which the larger community uses to indicate any additional information. Where they use it to show the kind that leads to etched outlines or something else depends a bit on the listener so fair enough they should describe why they think is higher resolution
I can accept 'transparency to recording' -- an ability to show the sonic differences between recordings rather than homogenizing. Otherwise, absent some electrostatic on hand for comparison, this sounds rather close to 'clarity.' Another example might be OTLs some of which offer see-through-ness.
Iirc "resolution is detail" was Tang's take who felt adding modifiers turns it subjective.
I think the two main poles are my definition and Peter's definition, no?
(I always thought "resolution" would be one of the easier terms to define!)
No, those are the dictionary definitions that I brought forth as the initial examples of what is commonly understood as resolution and the context for use in audio...as opposed to other definitions of resolution that have nothing to do with distinguishing one thing from another.All your examples are about things visual. Offer a definition that does not require a different sense organ to explain it by analogy. In audio, what is the quantum of resolution? What tool -- what something independent of your judgement -- is used to measure the resolution of a stereo system in a way that is repeatable and independent of individual opinion? What is the objective equivalent of 'pixel' in audio? Otherwise you're just tacking on resolution to some other attribute to claim there are degrees or increments of that attribute. Dynamic gradation, lifelikeness of timbre (timbre), pitch differentiation, etc.
Too simple...see my post above...there are different parameters to audio that will have differing degrees of resolution in a system. No system is perfect at all (or any of these) characteristics. You can have great spatial resolution but the system has poor dynamic resolution (think micro-dynamics) or timbral resolution (cold and analytical or overly warm)...or you don't feel that you can "hear into" the music (poor transparency resolution).Ron, this is my definition:
“Ron, to me resolution means information. Greater resolution means greater amounts of information. Natural resolution means information presented naturally. The more natural resolution that a system can present, the more listening to the system reminds us of listening to real music.”
What is yours?
What is yours?
The problem is when you say resolution do you mean timbrally, dynamically, spatially, transparency? No system resolves all these things equally well and so I think discussing a specific characteristics resolution is more meaningful than saying a system is resolving.I think your definition should stop after the first two sentences. The problem is that your natural sound overlay introduces tonal balance and transparency, and results in the confused mashup you wrote in Post #1,693 hereof.
Ked, How do you define resolution?
They are likely intertwined to some degree as well...if you have a high degree of spatial resolution then likely it contributes to a sense of transparency as well but not necessarily timbral resolution or dynamic resolution.I am not disagreeing with you. Timbrally, dynamically, spatially, transparency can apply the concept of "resolution" to these different attributes of sound.
I think in terms of how resolved are special or ambient cues.
I think you are applying the concept of resolution to different elements of sound. This makes sense to me.
The 6th definition of "resolution" in the American Heritage Dictionary provides: "6. The clarity or fineness of detail that can be distinguished in an image, often measured as the number or the density of the discrete units, such as pixels or dots, that compose it."
I apply this visual concept to sound, and so my definition is: the clarity or fineness of detail that can be distinguished in reproduced sound.
Resolution is a substantially objective concept, analogous to pixels in video (more pixels per inch equals greater resolution). Think of resolving power as in a telescope or a microscope, but in the context of sound.
I understand the pixel analogy. Can you give an example “in the context of sound” so that I can better understand what you are describing?
