Hey guys long time lurker and future Taiko owner with a question. Not much of a network expert but with the preferred architecture above, is there any provision to maintain Roon distribution for non critical listening? Can Roon living on a Taiko Extreme "talk" to the other devices on the separate subnet?
Thanks
That's a good question. I checked with Emile and he thinks it should be possible "with a pass-through" but this would need to be tested.
While I sincerely hope this pans out, this could prove problematic. Roon/RAAT has a history of using broadcast and multicast for discovery, and also moving ports and methods with evolving releases, so getting this right may be tricky, While multicast traffic is theoretically routable between subnets, broadcasts are not, so this may end up being messy. I sure hope to be proven wrong.
Hi Emile.. question for you. Would you recommend using one of the routers USB port to connect USB/Ethernet converter if an additional port is required? Wondering if it has impact to SQ? - Thx
Thanks
This is a highly simplistic solution and likely isn't as flexible as what you require - it doesnt allow you to do "unpolluted" critical listening while the non-critical system is operating. But I thought I would offer it on the off-chance it's helpful.
One potential option is to use a BluOS device that you can switch on and off. For my house i bought an older model for $200. You can connect it to your home via hardwired or wireless speakers. The device will attach wirelessly to your network and will show up as a Roon endpoint. When you do critical listening on your reference system turn the BluOS device off and disable the endpoint (Roon zone) in Roon. That should remove all deleterious impact of having it on the network. When you or your wife would like to listen around your home, turn the BluOS device on and enable the endpoint in Roon. Your non-critical system will have access to your entire library, your streaming services, and will be controlled via the same Roon interface as your reference system.
Reactions: oldmustang
Indeed we will just have to test several configurations for SQ. The purpose of the Router is to decrease network traffic on an “audio only” / “isolated” subnet. The more traffic you pass through, the less “useful” it becomes.
Sure that will have an impact on sound quality, plus you’ll need to have driver support in the router for that particular device.
Re: BPS Extreme
Will it be recommended to shut down in-between use?
Will the battery section for the ancillary be on powering connected devices if the power is off?
Thanks
Mn
Re: BPS Extreme
Thanks
Mn
With the BPS the power supply will always be powered on, if you shut it down you will only turn off the computer hardware, that will obviously extend the time before it needs recharging but you'll typically configure it to automatically recharge at for example 3AM so it's not like there's a real benefit to that. But you also don't have the "warmup" time anymore, it's on "song" within just a few minutes after a power cycle (power off/on).
so the question of the day from me is "when will the routers start to ship?"
Reactions: Rhapsody
Brilliant...
Thank you...
This is the best I've heard Ruin sound. It lacks the emotional connection I have using XDMS.
XDMS a good 30% better imho...
(No switch or nic)
Mn
Roon gets a LOT better sounding with the Switch/NIC. As it's been said before Roon with the Switch/NIC card can sound better than XDMS without the Switch/NIC.
That'll be an interesting moment if that happens...
It was amazing to me when I experienced it. Everyone's system is different etc. so who knows.
A question to Emile re length of DAC from router to switch……. Previously you stated that DAC from switch to Extreme should be shortest useable length. Does the same rule apply for DAC from router to switch
More accurate as in specifically addressing AP “noise”? Yes. I actually have a pretty decent solution already with a low power AP which is powered from one the Router’s USB ports though a small isolation transformer + filter. Making progress!
I was wondering if in this particular case PoE could be a cleaner solution, soundwise and aesthetically?
In my case any AP connection to the grid is more noisy.
I got Lifepo4 battery that is far superior to any other battery .
Besides the quality and amount of power it also depends what pollution due to bad antennas / signal strength / chosen wifi speed etc. your AP will spread around besides the audio signal. That is in case you have an inefficient AP or setup. A well tuned AP (after all it only serves your control device?) could save you some trouble and a gain in SQ.
Another interesting potential increase in SQ that I unfortunately can not test myself :
With the Extreme Switch hooked up before the Extreme, very likely, playing local files from the Extreme Server itself will sound better than without the switch .The sound-files do not pass the switch in this case, they only go downstream from the server to the DAC (not to confuse with the DAC cable) but gain in SQ because the switch is connected.
Disconnect the last DAC cable and you will hear, I am almost sure there is a difference. It will sound better with the switch connected. Obviously I assume when playing files the Extreme Server is buffering at least two tracks or more or ideally a whole album.
I guess regarding my first comment I am saying in this context if your noisy AP stays connected, that is not a good thing. With an Extreme Switch in place, also when playing local files and when you do not use streaming this could decrease SQ.
I hope I am wrong. But maybe someone will hear a difference?
