Nah. The Sasha are not boomy if set up properly.IMHO;
I agree with @tima about Lamm hybrid mono blocks. I heard them with watt/puppies -predecessor of sasha- and the sound was good. It was a better match than gryphon, mark levinson, boulder etc for wilsons back then and I believe it still is. Another good option is vitus which I prefer over boulder, mark levinson, gryphon and especially CH precision.
If you insist on CH go for M1.1 instead of 1.5, which I compared both on same system and there is a big difference between them in terms of sound quality.
If you insist on boulder then go for 2060 or 2160 not the 1000 series.
I don’t think any of the above mentioned amplifiers will have problems driving wilson sashas. In addition to those I heard many amplifiers with sasha or watt/puppies (more or less same topology). The ones I remember are KR mono blocks, a couple of Kondo amps, conrad johnson premier eights, a couple of audio researchs, Nagra 845s, Tenor hybrids etc. Although it’s possible to drive them with tube amps I recommend you to stick with solid state or hybrid amps.
Watt/puppy or sasha are famous with their boomy bass due to double bass drivers in a separate box. Placing them very close to side walls can exaggerate this problem. I recommend you to consider moving them to side where windows will be behind them.
Finally consider getting a preamp if you’re not gonna buy an integrated cause there is no shortcut in this hobby. Dac’s volume control may not compensate the need for a good preamp.
Neither watt/puppy series. But (there is a big but here) setting them up properly is very difficult. That’s the problem. Maybe w/p is a little bit worse than sasha but both easily become boomy IME.Nah. The Sasha are not boomy if set up properly.
www.psiaudio.swiss
I live in the San Fernando valley that regularly sees 100+ degrees temps - my room is 20x14. Pass X series put off far more heat than the Essence in my room (I wouldn't try XA160s as a result). One reason I didn't get Lamms a few years ago also was the heat. I do think the Antileon would be much warmer than the Essence. It's a darker, more chocolate sound too. Best of luck!2. Comfort is important when listening thus I am concerned if I can live with Class A amp that generates good amount of heat. Again, please consider that I live TX with small listening room, summer can reach 100F outside temp for 2-3 months. I am truly intrigue about Gryphon Essence but after more thoughts, I was going to exclude it from my considerations until I read @KeithR's reply - Gryphon Essence owner- who does not think it is space header. How large is your listening room, KeithR? I see that you live in CA, where the weather is probably comfortable most of the year.
Adding to KeithR's Gryphon experience (I have not heard the Essence), I owned the Antileon (original), Colosseum and Mephisto. The Antileon definitely threw out a lot of heat and somehow always stuck out in my mind as creating heat issues in the room during particularly hot days. Less so the Mephisto and even less so the Colosseum.I live in the San Fernando valley that regularly sees 100+ degrees temps - my room is 20x14. Pass X series put off far more heat than the Essence in my room (I wouldn't try XA160s as a result). One reason I didn't get Lamms a few years ago also was the heat. I do think the Antileon would be much warmer than the Essence. It's a darker, more chocolate sound too. Best of luck!
Interesting, thank you for the first hand feedback.I live in the San Fernando valley that regularly sees 100+ degrees temps - my room is 20x14. Pass X series put off far more heat than the Essence in my room (I wouldn't try XA160s as a result). One reason I didn't get Lamms a few years ago also was the heat. I do think the Antileon would be much warmer than the Essence. It's a darker, more chocolate sound too. Best of luck!
Good point, I would love to have an amp that can provide tons of detail at low volume.I have a smallish room as well. In my experience, a small room also needs a powerful amp. I can’t play the music too loudly. But at the low volume, I still got all the details. The bass is still punchy. If your amplifier is not powerful enough and you can’t play loudly due to size of the room, you won’t be able to hear what a big speaker can do.
Hi LL21,Adding to KeithR's Gryphon experience (I have not heard the Essence), I owned the Antileon (original), Colosseum and Mephisto. The Antileon definitely threw out a lot of heat and somehow always stuck out in my mind as creating heat issues in the room during particularly hot days. Less so the Mephisto and even less so the Colosseum.
Of these 3, second hand, I suspect the Colosseum could prove to be exceptional value for money and of the 3 maintains that pure Class A magic renown in the Gryphon design ethos...while also perhaps having the most neutral palette of the 3 as well.
That’s why I like CH, lots of detail. Another option not listed in your survey, Pilium. I’m biased as I own them. The box itself is stone cold after running for a whole day which suits the best in my small room. And lots of details even at very low volume with ease.Good point, I would love to have an amp that can provide tons of detail at low volume.
www.atma-sphere.com
