Yes, thank you. The Wilson XLFs are currently 2.5' - 3' from the wall behind the speaker. 5.75' is quite a lot, but I suspected (as with most panels) that they need a lot more space behind the speaker before it gets to the wall. The off-set is that the Wilsons are 2.25' deep, whereas the panels are are only a few inches (other than the base of the speaker)...so I wonder if they might in fact sit behind where the front of the XLFs are now.By "front wall" do you mean the wall behind the speakers?
In general, they don't need to be but prefer it.
Mine are about 5.75' from the wall behind them.
Do you mean 4ft is the suggested minimum @Taiko Audio? I’ve recently moved mine about 10ft into the room from about 7ft and it really helped with depth and layering of soundstage…The official recommendation is 4ft but there are several successful implementations with 3ft, and one customer has only 2ft of clearance and is happy with the result.
Do you mean 4ft is the suggested minimum @Taiko Audio? I’ve recently moved mine about 10ft into the room from about 7ft and it really helped with depth of soundstage…
Hello, You have the room to bring the Alsvyox out into the room a bit. You get more "layering" on the soundstage the further out in the room the panels are placed. Although every listener is different and if someone prefers the speakers further back towards the wall behind the speakers 1M from the back wall works, BUT you don't get the layering on the soundstage at 1M vs 2M or even 3M from the rear wall.Fantastic commentary here...questions about placement:
- Understand from the reading here and elsewhere that the sides of the room are less relevant and in fact in slightly narrower rooms, the panel science might give panels an advantage
- As for front wall...do these need to be far away from the front wall? Room is 11' x 15' - 18' x 40' (across open plan/dual room space) but the speakers are expect to be at 26' with slight inward curve of a quasi corner before it opens into the adjacent room.
Thank you all very much for your various answers. And Rhapsody, much appreciated. Will make sure to keep that in mind.Hello, You have the room to bring the Alsvyox out into the room a bit. You get more "layering" on the soundstage the further out in the room the panels are placed. Although every listener is different and if someone prefers the speakers further back towards the wall behind the speakers 1M from the back wall works, BUT you don't get the layering on the soundstage at 1M vs 2M or even 3M from the rear wall.
The Alsyvox panels are designed in such a way, I guess at this level they demand true SOTA gear, no compromises. So I would think unless you're prepared to engage in this kind of spend, there's no point considering lower end gear to drive them. When these panels land down unda, they're well over the 6 figure price tags, and so are those Genesis Tributes. So overall, we're looking at half a million just for amps plus speakers, ha! I can clearly see the dog house from here.
Yes agreed 110%, without a doubt!You don't have to go anywhere near that over the top to hear what the Alsyvox bring to the table.
I drive mine with a pair of Ayre MX-R Twenties and they sound absolutely spectacular, and I suspect so would a Moon 860A v2 based upon how it did with my Vivid Giya G1 Spirits.
Certainly improvements in amplification would be heard, but any good amplification would work, from McIntosh to Mark Levinson to many others.
There's no need to spend six figures unless the difference you hear is worth it to you.
Are not the Alsyvox main panels planars? That is, attached on all sides. A (true) ribbon is allowed free movement on half the sides.Alsyvox ribbons
Yeah I know, when I say "Alsyvox ribbons " I actually mean Alsyvox panel speakers with full magnetic planar ribbon tech. I'm not sure why on earth I referred to them as Alsyvox ribbons... guess I just get too excited whenever I hear or see them!Are not the Alsyvox main panels planars? That is, attached on all sides. A (true) ribbon is allowed free movement on half the sides.
Yes very true yaaar!RJ, at those prices, you could pay for an elaborate smuggling operation, get a container off a big ship, to a smaller ship, who could unbox the container and lower your new Botticelli X (and amps) onto an even smaller boat who’d sneak in the harbor under the cover of darkness. Think of the fun and excitement!
(My wife suggested I also post, for the benefit of RJ, the customs and border patrol, and all gov’t agencies on the lookout for suggestions of illegal behavior — the above is a JOKE, not meant to actually encourage said bad behaviors.)
