Safety first with LiFe batteries. Astonishing current delivery
Pretty easy to search this thread for posts by Emile or other Taiko Audio staff members (most everything else is speculation if it concerns products):I've been an enthusiastic follower of this thread. I was wondering if Taiko will be opening a dedicated thread. That would be convenient for discussing other products such as the switch, network card, the upcoming router, etc. This thread has been very unwieldy when trying to find specific information. I feel now, with newer products, this single thread will make it even more difficult to parse specific info relating to individual products. Thoughts?
NoI've been an enthusiastic follower of this thread. I was wondering if Taiko will be opening a dedicated thread. That would be convenient for discussing other products such as the switch, network card, the upcoming router, etc. This thread has been very unwieldy when trying to find specific information. I feel now, with newer products, this single thread will make it even more difficult to parse specific info relating to individual products. Thoughts?
Happening with both files and streaming...Are you streaming or playing local files?
It doesn't do it with the M12 Switch...Is this with streaming or with local files?
A pause with local files could point to an all too common troublesome roon release. Once queued, roon continues playing even if you unplug the network cable. I doubt the switch could be at fault im this scenario.
Thank You, Roon requested an update yesterday. Up to yesterday no issues so its seems as though it is as you suggested Roon related...Is this with streaming or with local files?
Good to hear and unfortunately not surprising at all. It seems to me Roon has considerably shortened their release cycles. Luckily we have XDMS to the rescue!Thank You, Roon requested an update yesterday. Up to yesterday no issues so its seems as though it is as you suggested Roon related...
I wish I had XDMS, for now still using TAS as my backup. To be honest ROON was working perfectly up to yesterday...Thank You Again...JohnGood to hear and unfortunately not surprising at all. It seems to me Roon has considerably shortened their release cycles. Luckily we have XDMS to the rescue!
So far so good with TAS. Now I'm wondering if I run ROON through my laptop and not ipad if that will prevent the pausing issue?Is TAS working as expected?
I'm getting pauses while playing files or streaming. Never had this happen. With Roon into the Album it stops, it says nothing playing, after about 5 seconds it go's back to where it paused. I have to hit play from here or play and it resumes. Its done this several times...Its not speeds I have 1gig...EDIT Just switched from the plain Jane inexpensive UTP CAT6a to CAT8, lets see if this stops the pausing...EDIT # 2 Its not the cables pause happened again...
