David Karmeli was right about the Tube Traps, at least in my situation. I prefer the sound without them.
Do these speakers use a line stage output into cross over including subs ?Specs, can't remember where I found them.
Reminds me of my infinity IRS betas, that also had active servo bass towers (had to supply your own amp though). The planar panels also had adjustments in the passive crossover…quite complicated to setup properly.Do these speakers use a line stage output into cross over including subs ?
so all is fed signal from preamp ?
I’m curious on this.
It seems Ron has plenty of knobs to turn lol.
Has anyone tried shutting down the subs and and move speakers to get timbre , natural tone and dynamics then add the subs ? just a direction to possible try
Maybe partially why they went with 8 inch woofers?I don't think at 250 Hz crossover, the bass towers can be considered just 'subs', since the range includes the upper bass and lower midrange as well. Depending on the crossover choices, you might presume the bass towers are audible contributors up to 400 to 500 Hz.
When I did my planar hybrids I picked a 10 inch woofer with a good smooth roll off (no breakup) at 1khz. I crossed at 300 with 2nd order with my Accuphase F25, driving both drivers with KR Audio VA-350i amps . Having a plastic sandwich woofer with very smooth roll off I think really helped the blend.Being able to sense spatial information with some reasonable clarity starts at 200 Hz or so, so the bass towers do contain spatial and imaging information at that crossover point of 250 Hz.
An industry pro told me this. Use or try the amp output to your speakers for bass ampsReminds me of my infinity IRS betas, that also had active servo bass towers (had to supply your own amp though). The planar panels also had adjustments in the passive crossover…quite complicated to setup properly.
Let us not forget that Ron prepare the room to be a listening room from the get go, wall stuffing, natural wood and special flooring/carpet included ! I would not expect his room to sound bad.Room treatments are not band aid. We can't expect that a couple of tube traps, arbitrary placed without any program or tough can forcefully ameliorate sound quality. IMO room treatment must be considered in an holistic way, considering the overall treatments, room, equipment and preference.
My room treatment has always been dynamic - I had to change it when switching speakers.
Edit - An old recipe : tune and set up the speakers without any room treatment. Improper room treatments can make set up very hard.
It's hard to tell how a drop in ceiling hight will affect the sound until you hear it, but high ceilings are normally an advantage for big powerful system, the adjustability of the system will come in handy.Secondly big drops in ceiling height can be a big issue. I’ve never experienced one like Ron’s, but I have heard a big ceiling drop height right in front of the listening position. That drop pretty much disqualified that system for best sound, no matter the equipment , and he has a million plus invested. Last I heard he is undergoing a major remodel, to get rid of the major design flaws for a good listening room.
my designer was Chris Huston. Chris did design in lots of extra bass traps, telling me at the beginning that it's not possible to know how much bass trapping might be needed, but that it's much easier to remove them than to add them later. over a 10 year period i did one by one eliminate all of those traps, except for the -4- floor to ceiling traps along the rear wall. the other design concept was retaining energy, which the room surely did. all diffusion, minimal absorption. in the end i needed to add surface cloth treatments to fine tune the room after i evolved enough myself to know where i was going.Lagunda, I would actually make that assumption, not that it would be horrible but certainly not at it‘s best.
I had a close friend who built a purpose built listening room, and prior to committing to the plans he had an acoustician assist. So he gets his new room months later and finally get‘s his equipment installed and fired up. He invited me over shortly thereafter and it was awful. There was a huge bass hump amongst other things, my friend was pissed because he had paid for a perfect room. The AcousticIan was called back out and he recommended some absorption panels at certain spots in the room, I helped my friend build them and install them and those helped immensely. The last touch was he added a center diffuser block from RPG acoustics. There might have been a few others but those were the big ones and it made all the difference. I think Mike Lavigne and other people who hired his design company experienced the same thing. That company tended to over damp everything, my friends system started underdamped, which I think I would always prefer, because you have at least not paid for products you have not ever needed.
Well middle C is 261 Hz...I would call that midrange already.Being able to sense spatial information with some reasonable clarity starts at 200 Hz or so, so the bass towers do contain spatial and imaging information at that crossover point of 250 Hz.
