...what role, would you say, buffering plays in your explanation of the workflow/digital chain and eventual output of music @Ratbastrd ?
Don’t like the name so my instinct is to keep this short.I suspect (just a guess) that the color users perceive as added space, clarity, lower noise floor etc, is in fact the error correction algorithms doing their job (correcting for lost or misaligned packets). If you break it down and think about it, it is really the only thing that makes sense.
LOL, sorry you don't like my nick. I've had it for years, and have been told it's fitting.Don’t like the name so my instinct is to keep this short.
When I break it down there is a very logical alternative, so it can’t be the only thing. The sound is getting better and better because of progressively less involvement of error correction. Much more likely when I consider that by the third switch, the stream has been through 2 previous error correction screens. Given that error correction is a noisy process, doing less of it would be very beneficial to the sound, allowing me to resolve and hear all those gorgeous elements you mentioned, all of which are completely correlated to the music and its associated recordings.
This would make sense. By improving clock, and flow of power, you are enhancing the traffic shaping capabilities of the device. It can reorder and better prioritize traffic, without have extraneous traffic (data/processes) to analyze.A modded Buffalo switch with good ps, OCXO clock, unused ports turned off was/is excellent, replacing the chain. In fact, I am/was hesitant to give it up for the forthcoming Taiko switch. Those guys say their switch will squash my beloved PFBuff. We'll see in another month.
You wouldn't hear packet loss unless it was catastrophic (buffer emptied). What you would "sense" most likely would be time shift or shrill/thin sound etc.I expected that packet loss would result in missing data, ergo drop-outs, skipping, etc. which I do not hear in my network.
Whether switches that are operating properly contribute to this is what’s pertinent here. You haven’t convinced me that a pair or even three daisy-chained switches will necessarily increase packet losses. Nor have you accounted for the situation where the successively deployed switches have been purpose-built for high-end audio.Lets start with one truism. There is packet loss in EVERY network.
You appear to be attacking a straw man that doesn’t come anywhere close to representing the configuration that @Re-tread implemented, which was what you initially reacted to.
Again I was trained that every network has packet loss and latency. The impact of that loss/latency is not linear. How much, where, when etc. dynamically impact the codecs behavior, specifically the error correction/concealment function when transcoding and reconstructing data at the far end of the network.
Not saying "Bad", suggesting what you are hearing (relative) to the original source material, is different due to the dynamic effects of codifying and transporting through the network, along with any introduced degradations in that process.But who says latency is a bad thing as far as sound quality goes? Those who hear and improvement from daisy-chaining switches are increasingly latency but maybe that’s contributing to the improvement they are hearing. I don’t know if that’s the case. Listeners have often found 100 mbps to sound better than gigabit, and what this tells us is that the pursuit of reducing noise requires us to come at these things differently.
It seems as if this is the audiophile debate of the month and it's making its rounds across multiple forums (using multiple switches). As for this statement, every playback format known to man is imperfect. The best we could ever hope for is an optimized approximation of the real event.As I understand it, neutrality is the holy grail for audiophiles. Digital audio (conversion, compression, transport, transcoding etc etc.) is imperfect. What you hear, will never be the same, when digitally converted and transported through a network, as the original source material.
The one thing I have learned with everything leading up to the NAP's is that everything affects everything and that conventional wisdom and age old standards no longer apply. It's not only a whole new ballgame, it's a different sport altogether.The more cogs in the process, the further from the source you get (in theory). If neutrality is the goal, eliminating variables should be the objective (again in theory). If on the other hand enhanced experience is the goal, then experiment away, just understand that all the variables are changing the experience (the reproduction is increasingly different the source).
Linn introduced their first Klimax Digital Streamer in 2007 and, while I wouldn't say that Sonos is in the same league, their zone players were using Ethernet a couple of years earlier at least; I started streaming with them in 2005. Given that this is going on 20 years, I'd hardly say that streaming music and network configurations are in their infancy, teens, maybe.It seems as if this is the audiophile debate of the month and it's making its rounds across multiple forums (using multiple switches). As for this statement, every playback format known to man is imperfect. The best we could ever hope for is an optimized approximation of the real event.
Technology concerning streaming music and network configurations are still in its infancy in the whole grand scheme of things. Looking back over the years, power cords didn't make a difference at one point and the debates raged. Now, it's established that they do. There are many more examples that I could cite over the decades but I think you get where I am going with this.
Tom
Spot on!It seems as if this is the audiophile debate of the month and it's making its rounds across multiple forums. As for this statement, every playback format known to man is imperfect. The best we could ever hope for is an optimized approximation of the real event.
Tom
Okay, you got me there. Teens it is.Linn introduced their first Klimax Digital Streamer in 2007 and, while I wouldn't say that Sonos is in the same league, their zone players were using Ethernet a couple of years earlier at least; I started streaming with them in 2005. Given that this is going on 20 years, I'd hardly say that streaming music and network configurations are in their infancy, teens, maybe.
Chris
I know the guy's at Sonos very well, worked with them for a number of years. Their solution to "whole home audio" very much centered on the problems we've been discussing. Much of today's mesh networking technology was originally ideated in the Sonos laboratories.Linn introduced their first Klimax Digital Streamer in 2007 and, while I wouldn't say that Sonos is in the same league, their zone players were using Ethernet a couple of years earlier at least; I started streaming with them in 2005. Given that this is going on 20 years, I'd hardly say that streaming music and network configurations are in their infancy, teens, maybe.
Chris
You have it exactly right!![]()
No idea why any of this should be important. A large number of dacs use a substantial fifo with a subsequent reclocking and there is no reason the specifics of the transport mechanism should play any role as far as data integrity and correct timing are concerned. Which leaves noise as the only possible explanation for network sound.Problem is IP networking was never designed for low latency, high definition media transport. It was designed to be robust & reliable and most importantly simple. How long it takes for packets to get from A > B and in what condition, was never part of the equation. Best effort is good enough.
I disagree, but we'd need some very expensive test equipment to resolve the debate.No idea why any of this should be important. A large number of dacs use a substantial fifo with a subsequent reclocking and there is no reason the specifics of the transport mechanism should play any role as far as data integrity and correct timing are concerned. Which leaves noise as the only possible explanation for network sound.
