Congrats to your purchase! So what made you decide? How does your rig look like? Just curiousI just bought one myself. I quite like it.
Andrew Quint at TAS in a recent review compared the inbuilt DAC to his Ideon reference DAC and found no meaningful differences between the two. The Ideon retails at 49k USD.Expensive yes but considering it has a built in dac/pre then it doesnt look so bad at all.
Cant wait to hear it!
I had to know how it sounded and one became available an an attractive price. I couldn't resist!Congrats to your purchase! So what made you decide? How does your rig look like? Just curious.
Does the unit you are using include a DAC? And do you still use the MU1 to stream to it (via SPDIF)? And the Ethos feeds the MU1 in case you want to play CDs?I had to know how it sounded and one became available an an attractive price. I couldn't resist!
Yes sir! You have it exactly right. I am using the DAC inside it. It seems quite wonderful. I compared it to the DAC in the Ethos, and to my borrowed Ideon Audio Absolute DAC. It stands up well to both. My version of the BACCH-SP does not have AES/EBU inputs so I stream from the Grimm MU1 to the BACCH via SPDIF. The BACCH is a ROON Endpoint so I can stream from the MU1 to the BACCH via Ethernet. I miss out on all the MU1 FPGA processing but it's fun to compare.Does the unit you are using include a DAC? And do you still use the MU1 to stream to it (via SPDIF)? And the Ethos feeds the MU1 in case you want to play CDs?
Good to hear that you are having fun! Interesting that the processing is not startling, but given your beautiful setup it isn't surprising. But the head tracker sounds like it would be interesting to use.Yes sir! You have it exactly right. I am using the DAC inside it. It seems quite wonderful. I compared it to the DAC in the Ethos, and to my borrowed Ideon Audio Absolute DAC. It stands up well to both. My version of the BACCH-SP does not have AES/EBU inputs so I stream from the Grimm MU1 to the BACCH via SPDIF. The BACCH is a ROON Endpoint so I can stream from the MU1 to the BACCH via Ethernet. I miss out on all the MU1 FPGA processing but it's fun to compare.
I use an AES/EBU cable from the Transport of the Ethos to the MU1. And just for giggles I have unbalanced outputs from the Ethos to the BACCH. Just in case the special magic the Ethos does with silver discs requires both the Transport and the DAC. So far that does not seem to be the case. I also use balanced cables between my Gryphon Legato Phono Preamp and the BACCH. I know I know why would you digitize the pure analog of the turntable. For giggles.
I want to borrow some very expensive unbalanced cables and try the BACCH connected only to the Tape Monitor Loop. That way I can hear my system just as it was pre-BACCH and hit the Tape Monitor button to hear just what the BACCH does.
Edgar wanted me to remove the Gryphon Commander from the system and just hook the Apex directly up to the BACCH. I may try that some day, but not this day.
I switch the BACCH processing in and out and the difference is not startling. It sounded really good Pre-BACCH and it sounds very nice with the BAACH Processing.
Antigrunge, I am just going to say yep, you got it. Good job! The Electronic manipulation would send you out of the room before a note is even played. It's that awful! Gosh!
I do have a lot of videos already on the Bacch. Right now I just have the Bacch4Mac, but it's been upgraded to the full pro status that includes the headphone and many other additions.The Audiophile Junkie has been releasing a lot of content on the Baach SP, especially related to the Baach4Mac software so much so he joined as a in home dealer. Here is latest released episode.
I have been giving it a lot of consideration but have some concerns how it really integrates into systems. It doesn't look like it fits into systems with a streamer. It seems you need to set up the Mac as a Roon Endpoint to feed the DAC and if you want to use it with an analog source it is necessary to use the RMD Babyface which goes out through your DAC as well. Maybe the physical device is a better alternative but I still think everything goes through it similar to the Mac.
Anyone with insight on using it with analog devices and streamers?
Those who are members of my site can also get a taste of what it's like by sending me their favorite WAV file and distance between the speakers as well as listening distance to your head. I can create a standard filter based on those dimensions and basic room and gear assumptions that will at least give you a percentage of what you can expect from the full product with binaural in-ear measurements and head tracking. It's basically the same as buying the $900 intro version for a taste.
My BACCH-SP adio is a Roon endpoint and works well with my Grimm MU1 and Pink Faun streamers.The Audiophile Junkie has been releasing a lot of content on the Baach SP, especially related to the Baach4Mac software so much so he joined as a in home dealer. Here is latest released episode.
I have been looking at the Baach4Mac and the best method was to replace the Innous Zen with the Mac mini as the Roon endpoint. I was on the phone last evening with Jason and Edgar discussing this.My BACCH-SP adio is a Roon endpoint and works well with my Grimm MU1 and Pink Faun streamers.
