I placed an order, and am trying to pay with Transferwise, but I've encountered this error I've never seen before:
We cannot currently accept payments to this recipient.
Does anyone else have this issue?
Yeah, transferwise / wise blocks accounts once a certain treshold is reached, think it’s 250K, we have one account left which hasn’t maxed out yet. E-mail us for the acc number.
Reactions: jelt2359
the DAC cable is offered up to 7m- is there any SQ penalty to get a longer one? As a longer length helps with placement flexibility...
Order placed :)
Thanks Emile!
I believe I asked you this question before, but I'm not sure I understood correctly.
It will be possible to send you back the Extreme for modification in order to include the battery power supply.
But it will keep the same design.
The power supply will power the Extreme internaly and the external switch as well.
Is this correct?
Do you already know what the dimensions of the case will be?
Correct, further details to be announced.
Reactions: SwissTom
I may have missed it but has there been price guidance yet on the router?
7m is the maximum length.. Longer requires an active cable which unfortunately severely degrades SQ (to fiber levels)…
Sorry what I meant was: is there any SQ benefit to choose 2m over 7m, for example?
Reactions: Taiko Audio
to all the switch zealots......do they need to be seated on a rack or is the floor sufficient. I ask only to try to determine which length cable I need to order
Reactions: J117
Thanks! I will go with 7m then to maintain more flexibility with regards to placement.
If one is going to power the switch by Takio BPS, I am sure the switch is better sit closer to BPS with short DC cable.
I thought the same
