There is only a choice of RJ45 OR fibre as input, right?
I placed an order, and am trying to pay with Transferwise, but I've encountered this error I've never seen before:
We cannot currently accept payments to this recipient.
Does anyone else have this issue?
Which of RJ45 or fibre would work best with the upcoming Taiko router?
My wife thinks it's a beautiful object!
Correct, further details to be announced.Order placed
Thanks Emile!
I believe I asked you this question before, but I'm not sure I understood correctly.
It will be possible to send you back the Extreme for modification in order to include the battery power supply.
But it will keep the same design.
The power supply will power the Extreme internaly and the external switch as well.
Is this correct?
Do you already know what the dimensions of the case will be?
the DAC cable is offered up to 7m- is there any SQ penalty to get a longer one? As a longer length helps with placement flexibility...
I may have missed it but has there been price guidance yet on the router?
Sorry what I meant was: is there any SQ benefit to choose 2m over 7m, for example?7m is the maximum length.. Longer requires an active cable which unfortunately severely degrades SQ (to fiber levels)…
So to keep it simple..."what length sounds best"They do sound ever so slightly different but I would fail a blind A/B test.
If one is going to power the switch by Takio BPS, I am sure the switch is better sit closer to BPS with short DC cable.Thanks! I will go with 7m then to maintain more flexibility with regards to placement.
I thought the sameIf one is going to power the switch by Takio BPS, I am sure the switch is better sit closer to BPS with short DC cable.
