Has this come in yet?… I’m very interested as to how this works outJust place an order for the Silent Switch Extreme version without any LPS inside. However, the switch is powered by Firebird (another Ediscreation LPS). Make the two things ie switch and Firebird LPS as a package.
Eager to know the performance in the system as the Silent Switch will be the third switch in the present system.
I have a standard Fibre Box between my Innuos server and my Auralic digital stack and it’s an excellent piece . Having the Fibre box in this position does seem to make my basic Innuos Zenith III a better server, or should I say it feels (sounds) like a typical sonic gain from a better server. The thing I can say with absolution is when I change ethernet cables from the Fibre Box to the Auralic Aries G2.1 I can immediately hear a difference . More apparent than if the Box was not there. I like this bonus a lot.
My hope is that with the same combo you have ordered I’d receive more of the same . I guess I just wanted someone to jump in the water first on this one .
If I do this I’d move the normal Fibre Box II into the position between a 40’ run of Wireworld Starlight cable and whole house router…. It would look like this:
~Cable company router/modem >
~Wireworld starlight 40’ >
~Fibrebox II >
~Wireworld starlight 3’ >
~Ediscreation switch ( used for several devices)>
~AudioQuest Diamond ethernet 6’>
~ Innuos Zenith III
~ AudioQuest Diamond 3’>
~Fibre Box Extreme with Firebird LPS >
-Shunyata Sigma ethernet 6’ >
-Auralic Aries G2.1/ Vega G2.1
anyway, please report back when you have implemented this …. Please and thank you
