Recommendation for 6l6
retired farmer
Active Member
Oct 18, 2022
150
54
33
57
I am looking for a quad of 6l6 power tubes for my line magnetic 124a monoblocks. What would you recommend? I have a set of sohpia electric 274b rectifier tubes ot it that I like. The amps call for either a 6l6 or 350b tube s . I bought a quad of tad 6l6 tubes for it the beauty is all gone.
I don't have that much experience with 6L6 tubes, but I want to give you a few general pointers.
I usually buy at big, well-known dealers. They might be more expensive, but they give you a warranty. It is super important with NOS tubes.
I would start with a few sets of inexpensive new production tubes to see which sound signature fits your system the most, before you pull the trigger on expensive NOS tubes.
Reactions: retired farmer
If I were buying 6L6s new, I would start with JJ. Matched quads are readily available.
If your amplifier can handle an extra 5 watts plate dissipation :
Or even better if you can run to them :
If your amplifier can handle an extra 5 wats plate dissipation :
Best to consult the manufacturer about that.
I order two quads of these the other day on there black Friday pricing. They were extra cheap and the little write up I saw was quite good. Now to find out if they will exchange in my amp apparently they do another of times but not always.
Nice catch! Let us know when they come to you. I'm very curious about their sound.
I got the two quads of tubes today. Anyhow right off the get go I like them. They seem quick and articulate. Tone seems good and they are more musical than the tads are. Likely better around but so far seem good and they were very cheap. I will let them break in for a week and if I still.like them I will buy a few more quads to stick in a drawer. Cheap enough it might be worth a try for anyone interested. One other thing they are much shorter than the 6l6 tubes I have. Personally I like them in my line magnetic monoblocks much better than the tads I bought.
Regards Tom
Thanks
Regards Tom
Great to hear that you like them :) Cheap and good is my favourite combo. Do the shorter glass fit the looks of your LM monos?
Thanks
Here are a few pictures of the Russian tube that viva tubes said worked most times. As you can see in the first picture does that look OK
Seems to be brighter than any other tube I have. Played them about three hours now. The first few hours are really quite fun to hear the new tubes break in and sound better as time passes .fourth picture is the Russian number. Third picture is a size comparison to the tad 6l6 I had in there before
Reactions: AMR / iFi audio
I didn't see your original post back in November. I have a Line Magnetic 518IA integrated amp and use NOS GE 6l6GC tubes in it, enjoy the sound with those. I have a pair of RCA 6l6GCs and also NOS RCA 1614s to try when the GE's need replacement.
