I also heard good things about the Lenco tonearm, hence my previous questionAgree! Theres something about that underestimated lenco beat.
Using denon 103 and shure m3d and sc35c/n35x on my lencos. I also like the L70 tonearm.
I also heard good things about the Lenco tonearm, hence my previous question![]()
Excellent player/tonearm for a Decca/London cartridge .Well Tempered Simplex 2. Temporary table... just arrived because I hate digital. Sounds pretty dang good for $1000 used. 4-5 more weeks until my 401/Schroeder CB gets here. The waiting is really hard but this is a fun listen.
That's one loooong record spindle you have there lolWell Tempered Simplex 2. Temporary table... just arrived because I hate digital. Sounds pretty dang good for $1000 used. 4-5 more weeks until my 401/Schroeder CB gets here. The waiting is really hard but this is a fun listen.
I know! I couldn't tell which side was the bearing side at first. Weird little table. Also better sounding than a bunch of other tables I have owned that cost a hell of a lot more...That's one loooong record spindle you have there lol![]()
Huh. That's the Amari Micro-Seiki tribute, isn't it? Is yours modded? How do you like it?My current Stable Mates....
Cheers.....
Yes, it’s a Micro Seiki 8000 clone. After some initial problems , due to some quality control issues, that Peter Noerbaek of PBN AUDIO, helped me sort out, it’s definitely a Huge Bang for the buck ( approximately 5500.00 delivered to US for the “Blue” version). The standard silver is less expensive.Huh. That's the Amari Micro-Seiki tribute, isn't it? Is yours modded? How do you like it?
The BL-91 is such a BeautyMy current Stable Mates....
Cheers.....
Very interesting. Apparently Acoustical Systems does (or did) a series of mods to the Amari:Yes, it’s a Micro Seiki 8000 clone. After some initial problems , due to some quality control issues, that Peter Noerbaek of PBN AUDIO, helped me sort out, it’s definitely a Huge Bang for the buck ( approximately 5500.00 delivered to US for the “Blue” version). The standard silver is less expensive.
The only mods are some custom footers, and Walker Lead pucks, along with a solid 2 inch thick acrylic sub base for the motor to sit on. Definitely changed the sound in a direction that I found to be beneficial.
Cheers....
corbysaudio.com
The motor died on me after 2 days . Apparently something went out on the Control Circuit Board.Very interesting. Apparently Acoustical Systems does (or did) a series of mods to the Amari:
Acoustical Systems Amari Turntable Sold
We are the exclusive Canadian dealer for this fabulous table. This is an Amari LP82s table modified by the German high end manufacturer, Acoustical Systems. This is a Micro-Seiki RX-5000 clone, using an 18mm ceramic-shaf...corbysaudio.com
What were the QC issues you encountered? Is there space to add a second tonearm on the top left? Looks like there is, but that armboard/wing, which makes sense for arm stability, also seems to take up a lot of real estate.
Speed control is solid?
market arm boards available, and some even from Micro Seiki ( original metal arm platforms).
I've been looking at the Amari too but couldn't pull the trigger because I've heard about some issues but maybe I should have. That's a gorgeous table.The motor died on me after 2 days . Apparently something went out on the Control Circuit Board.
Fortunately I had another, older less expensive Amari table that uses the exact internal Circuit board, ( with a few minor lay out differences).
Peter at PBN AUDIO was able to swap it out. Unfortunately when you buy from China, you are taking a gamble. I have been in correspondence with the exporter and have yet to hear when they will have Amari send me a replacement Circuit board.
The table runs quietly and maintains very stable speed. Usually runs at 33.333, up to 33.355
There are two other available possible arm posts.
There are afterView attachment 98250 market arm boards available, and some even from Micro Seiki ( original metal arm platforms).
Cheers...View attachment 98251
I was going to buy one of the Acoustical Systems ones in Dec 2020. Arranged top go to London to pick up (during Covid so had to be careful etc) but the day before they cancelled as the speed had gone wrong on it. They emailed a week or 2 later to say it started working properly...I decided to give it a miss.Very interesting. Apparently Acoustical Systems does (or did) a series of mods to the Amari:
Who was the dealer you were working with in London, out of curiosity?I was going to buy one of the Acoustical Systems ones in Dec 2020. Arranged top go to London to pick up (during Covid so had to be careful etc) but the day before they cancelled as the speed had gone wrong on it. They emailed a week or 2 later to say it started working properly...I decided to give it a miss.
I suspect the controller needs some work on it. I was surprised as I understood Acoustical Systems had done work on the PSU/controller, so expected it to be above the usual Chinese work.
Anyway, no regrets on my part as I suspect once a problem, always a problem. My Japanese DD's which are 40plus years old seem to carry on.
HMF Solutions. I got the impression they didn't really know much about it. I asked questions about arm mounting, belts, arm boards and compatibly with MS ones. I suspect they just imported them on the basis of Acoustical Systems name.Who was the dealer you were working with in London, out of curiosity?
The concern I had was to do with serviceability and who would do it, Amari, Acoustical Systems (as it was a unit they had tweaked) or just a regular audio service company.
Not like buying SME, Technics etc where you know there is support.
