Wilson Audio has announced the new Alexia V. Here's a link to more information:
https://www.wilsonaudio.com/products/alexia/alexia-v
Some data:
Alexia V - U.S. MSRP:
Standard Finishes: $67,500
Upgrade Finishes: $69,500
Custom Finishes: $71,500
Premium Finishes: $79,500
Alexia V Specifications:
Measurements:
Nominal Impedance: 4 ohms / minimum 2.59 ohms @ 84 Hz
Sensitivity: 90 dB @ 1W @ 1m @ 1k
Frequency Response: 19 Hz – 33 kHz +/- 3 dB
Minimum Amplification Power Recommended: 20 watts/channel
Drivers:
Woofer: 8 inches (20.32 cm) Cone Material: Paper Pulp
Woofer: 10 inches (25.4 cm) Cone Material: Paper Pulp
Midrange: 7 inches (17.78 cm) Cone Material: Paper Pulp Composite
Tweeter: 1 inch, Dome (2.54 cm) Material: Doped Silk Fabric
Dimensions:
Height: 53 3/32 inches (134.86 cm) w/spikes [Variable]
Width: 15 3/4 inches (40.01 cm)
Depth: 24 3/16 inches (61.41 cm)
Enclosure Type:
Woofer: (Rear Ported) Material: X-Material
Midrange: (Rear Vented) Material: X-Material/ S-Material baffle
Tweeter: (Sealed) Material: X-Material
Damping Inserts: Material: V-Material
-Woofer Top / Midrange Top / Acoustic Diodes
Product Weight:
Weight Per Channel Uncrated: 265 lbs (120.20 kg)
Approximate Shipping Weight: 795 lbs (360.61 kg)
Some data:
Measurements:
Drivers:
Dimensions:
Enclosure Type:
Product Weight:
