Windows Version of XDMS App
You can listen to XDMS and work on your PC at the same time
This does naturally beg the question... 'who' can? ;)
Just wondering if any updates on progress or how sound quality is sounding vs TAS as XDMS development continues?
Looking for recommendations regarding footers for the Taiko Extreme...
I realize Taiko's own Daiza Isolation Platforms and Critical Mass CenterStage 2M are heavy favorites.
Any others? ...Footers, specifically. Thanks.
For those of us who don't own a PC I think we would rather listen to XDMS in our sound rooms taking it all in :cool:
TAS app expires in 25 days o_O
The main benefit of having Windows and Mac versions of the XDMS App, it makes introducing, the XDMS interface and setting up for Extreme Users that much easier.
We can TeamViewer in and see and click on the App. With TAS it was iphone video call or imagining in our heads what was on the screen
The fact that we have compiled a Windows version and about to compile a Mac version is an indication that the roll out is not far away
Christiaan has signed off on this upcoming release, but the development of the SQ is ongoing and will be for a long time.
XDMS will be the software that keeps on giving SQ upticks
from your mouth to our ears
Reactions: aLLeARS
Hmmm, does this run in a browser or is it a real windows/Mac program?
I have neither OS, I use either the tas Android app or a browser on a Linux laptop.
Please confirm you have me covered as well for xdms.
The Windows Web App runs as a standalone app. It is in addition to the dedicated iOS and Android apps.
As Ed mentioned, XDMS is not yet finished and we're still working on implementing further improvements. But even as it stands, XDMS is a marked improvement over both TAS and Roon. I personally leaned more toward TAS than Roon but I also felt that both have their respective merits and tradeoffs. XDMS offers the best qualities of both in a presentation that is closer to the Taiko ideal. The precise perceived differences will depend on the version of Roon, but typically, XDMS sounds more agile, lively, and expressive than Roon yet more fluid and organic than TAS.
No worries
we can Anydesk into your Android tablet
No worries
Ok. So the only thing that goes away is the browser access that lms has at ip:9000? I can live with that :)
Downloaded anydesk to my android devices. Standing by for further instructions.
Edit:. Corrected ip port.
Ok. So the only thing that goes away is the browser access that lms has at ip:8080? I can live with that :)
You get a TAS browser window with an address of ip:8080? Is that a Linux thing? My web browser TAS window is at ip:9000.
Steve Z
Steve Z
As XDMS is written from the ground up and no longer includes elements of LMS or TAS, that particular kind of interface will indeed be gone.
Reactions: Steve Williams
Need help. My taiko extreme server was completely powered off for the last 3 weeks. I turned the rear switch to on position and a few minutes later the front power switch, nothing. Tried several times. Powered off completely. Then attempted again. No luck. Was fine 3 weeks ago when powered down. The main fuse is fine. You hear an internal click when the rear switch is power on and you can see that internal lights are on through the cooling holes. Any ideas?
Yes, send an email to support@taikoaudio.com
Just a thought, but perhaps the IP address was reset? If so, the extreme is not at the same ip as previously assigned.
Use an IP scanner (like Fing on Android, don't know what on windows or apple) to see
1. If the extreme shows up
2. what IP address the extreme is using.
3. Compare that with the IP address the tas app is using
Good luck
Do you mean that when you press the front button, the white light around it does not turn on?
