Roon Via airplay only , both servers are top notch , I like the Aurender app it's simple , I'm waiting for XDMS for the Taiko Extreme before deciding which I like more .How does the taiko compare to the N30? Can the Aurender use roon?
I do like my n30saRoon Via airplay only , both servers are top notch , I like the Aurender app it's simple , I'm waiting for XDMS for the Taiko Extreme before deciding which I like more .
Korean reviewer wrote that W20SE is no match for N30 any longer.Wouldn’t the W20SE be a better comparison to the Extreme? Maybe even with the new clock? Wonder what price diff is for W20SE+clock vs Taiko….
Wow I am not going to take it for home audition.The new Aurender clock is 30k!
It used to be but not anymore.Isnt the W20SE the flagship?
Thx. Looking into it! Not sure if I like that Roon is unavailable…. Server is next for me down the line….
P.S. I must add that 30K for a clock is absurd…
How many units can they expect to sell? Also internal parts of exquisite clocks are costly.I agree that the price is absurd. IMO the N30SA beats other streamers even without the clock. Adding the clock though could make it better? I don’t know of anyone who has heard the clock, but would like to see some reviews.
I'm using a omega USB and no didn't upgrade cables , it's at 2nd home not used muchI do like my n30saand I had a taiko before
agree simplicity of the software is great. Rau what connection do you use to the dac? Also have you upgraded the power and signal cable between the 2 units?
I picked up N30 very late last night.
Thus I could not sleep.
After running demagnetizing tracks for one hour, I started listenin to it.
Wow it gives very transparent window with fine details.
It may change its sound after a week of break in.
But my impression so far is that N30 is in another league above N20 althugh N20 could be the best value.
Below video was taken with N20.
What's the big secret? Start at post #148
MSB Select II - Page 3
In native mode. I was actually wondering, what enhanced in the menu means and does.www.audioshark.org
Thanks for your compliment.Congrats. And that’s a nice looking system!
The N30 takes a while to burn in. It only gets better.
