Thank you!
I took a look at the website and I don't see a problem. You should be fine.
I hope this helps.
I hope this helps.
What exactly is there to "settle" in construction comprising of a steel ball sandwiched in between two chunks of aluminium?Wow. Epic. I love it! After years and years and years and years of pretending, I finally understand the meaning of the phrase, "Stupid is as Stupid does". What Stupid does is create a report on feet before they are settled and present the noise as "professional discovery ". And what Stupid is, is not realizing how stupid that is. The settling process is nasty.This is stipulated. To pretend this is new news is, well, stupid.
I do own both CS2 and CS2M and gave them both a fair chance. So now that we have the ignorance ruled out - what gives?Try them and you might understand. Otherwise ignorance is bliss. .
that should be of no issue whatsoeverf your CM2 footers were purchased used, could it be that the unit you used them on was similar in weight as the previous owner?
Play songs you like and know. Remove the CS footers and play the same songs again. Keep the 4 feet close to where you removed so that you can easily put them back in which I’m betting you willive had mine under my aon s10 sig for 3 weeks now gonna do an a b. whats the best way
May I ask which size you used and the specific component you tried them under. Perhaps, I can help?
No help needed. Thank you though.May I ask which size you used and the specific component you tried them under. Perhaps, I can help?
BrianNo help needed. Thank you though.
I think they were CS2. In order to be sure, I'd have to go back and look at my pictures as I don't honestly remember at the moment. It was definitely pre-COVID. My experience around "settling time" would apply to all generations though. I remember this audible settling time being mentioned from the very first product.Brian
IIIRC you used first generation CS footers loaned to you by your dealer 3-4 years ago. Correct me if I’m wrong but you have never heard CS2 or CS2M
Pretty sure they were CS2. As I recall you said you did observe a change under your phono stage but that the position of some instruments weren't right? Don't recall your specific feedback so excuse me if I have it wrong.I think they were CS2. In order to be sure, I'd have to go back and look at my pictures as I don't honestly remember at the moment. It was definitely pre-COVID. My experience around "settling time" would apply to all generations though. I remember this audible settling time being mentioned from the very first product.
Joe, yes, I could clearly hear the effect of the footers. But over several weeks and months, I didn't observe "settling" or changes to the effect the footers imparted on the sound.Pretty sure they were CS2. As I recall you said you did observe a change under your phono stage but that the position of some instruments weren't right? Don't recall your specific feedback so excuse me if I have it wrong.
Cheers, Joe
My reply was that if the footers he is using were previously used, perhaps his component is similar in weight. That could explain why he did not experience the break in. I have found that if I move mine to different equipment it takes time for them to resettle.that should be of no issue whatsoever
