No Salelectric is correct that if you needed to do this via resistance, you'd do it at the input. I'd probably do it at the attenuator by giving the one side a heavier load by a smidge and test by ear or measurement of a mono signal.
I don't know if you have an integrated tube amp or standalone, but if separates, make sure which component is causing the problem first. Definitely check / swap the tubes including the rectifiers assuming they are tube and not silicon. Tube swapping is the easiest and probably most likely thing to do to fix this.
Ah, bummer... Okay, well thanks for at least explaining that to me so that I understand why everyone is so against that ideaThe simple answer is NO. While a resistor in series with one speaker will reduce the volume of that speaker, you have no idea what value resistor to use. It could be 0.5 ohms or 1.0 ohms or 4 ohms or 8 ohms. Nobody could know the value in advance because no one knows how much louder one channel is than the other and, even if we did know, the value would depend on the particular speaker. Lastly a series resistor would likely cause tonal balance problems because speakers have varying impedance at different frequencies. A series resistor will therefore reduce the volume by different amounts at different frequencies.
Just swap the tubes and you can solve the problem instead of putting a band aid on it.
Since you may not have experience with tube amps, you should know this—-always wait several minutes before powering up the amp again. Therefore, before changing tubes, turn the amp off and let it cool down for 5 or 10 minutes. Then swap tubes and turn it back on. Not only is it safer to remove tubes after they have cooled a bit, but the delay is also important to avoid stress on the tubes and power supply.
Ok, make sure you switch all the tubes left to right, once done and there's no difference, then switch the input interconnect cables left to right.
If the input cables result in the level change switching sides then the issue is upstream of your amp.
If the levels didn't change sides now switch your speaker cables. If the level difference switches sides then it's your speaker. If not it's your amp and it'll need service, if there's an issue with it it's likely causing a decrease in sound quality or it could lead to further problems so please DO NOT attempt to fix this issue by inserting a balance control.
Good luck!
edit: I hope that makes sense and I got the logic correct, I just got back from a long weekend without enough sleep so I want to add a disclaimer...
Sounds like very good advice, thank you!Having a large channel volume difference will have an obvious fix if you have patience and diagnose systematically. It's worth learning these skills. Take the advice already offered and then go to the tech. Find out what gets fixed and what may have caused it so you can deal with it if it happens again. Your system sounds complicated. Be prepared if it's not the amp....
A Mills wire wound resistor on the output will absolutely sound like crap. Try it for fun, but there's no learning experience here - 2 wrongs don't make a right!
The potentiometer channel imbalance can cause the difference in volume. How much do you turn the potentiometer for your listening levels? 9 o'clock?Sounds like very good advice, thank you!![]()
I used Mills non-inductive wirewounds for anode loading for a long time. When some of those became noisy, I bought new replacements, but their quality was not the same. The old ones were black and the new ones are brown. I found out that they had moved the manufacturing to Mexico. I suspect they are now crimping the ends, which can cause noise when the temperature rises. I changed to Caddock military grade non-inductive thick film resistors. They are large and heavy, but really excellent. Very stable, durable, and sounds very transparent.
Have you checked the voltages (B+, heater, bias if present)? The two channels might have separate regulators and the voltage might be lower on one.Heh... No, no, I gotchaHonestly, that was the very first thing I did, just like you said (with the exception of the speaker thing
) When I changed R/L speaker outputs from the amp, the phenomenon did change sides showing that the same channel on the amp was 'bad'...
Oh no... I would never DREAM of adding a component in the signal chain like that no way... If you saw my system and the way it is designed, especially the tall multi-driver open baffle dipole line-arrays with only ONE capacitor on each channel going just to the ribbon tweeter, and all others full range (12/side) you'll see that I am quite loathe to introduce ANYTHING into the signal chain that I don't have to.
BUT... with that said... (here come the dumb part) I STILL am rabidly curious about just throwing a high quality resistor (Mills wirewound as you had suggested for other purposes?) just to see how it affects the sound. I KNOW that it affects the inductance of the, in this case, 13 drivers a side, differently, and if it sounds like crap I'll take it off.
The good news is that someone on the Steve Hoffman Forums who also lives in the San Diego area did recommend a technician not too terribly far away, so there is that if I don't completely paralyze myself trying to lift the damn 90 pound thing!
Before you go down the rabbit hole, did you reverse channels (both input, then output next) to determine which side had the attenuated output? Very unlikely an errant resistor accounts for a 3dB change in loudness on one side. Agree a tube is more likely but you would benefit from doing some straight forward diagnostics first.
PS Love the vinyl collection. Looks like my old dorm room!!
Caddock makes excellent parts, great choice. Mind one thing, they are not as resistant (hehehe) to overloading. This is common for all film resistors. Wirewounds are durable since their resistive element is thicker and has more thermal mass.I used Mills non-inductive wirewounds for anode loading for a long time. When some of those became noisy, I bought new replacements, but their quality was not the same. The old ones were black and the new ones are brown. I found out that they had moved the manufacturing to Mexico. I suspect they are now crimping the ends, which can cause noise when the temperature rises. I changed to Caddock military grade non-inductive thick film resistors. They are large and heavy, but really excellent. Very stable, durable, and sounds very transparent.
