LampizatOr Horizon - Tube Rolling Paradise
Golum
1,812
2,575
405
Lausanne, CH
christoph
4,674
4,071
825
Principality of Liechtenstein
What lampi has given you guys is the most adaptive
digital to date and all SS dacs should be worried
while digital is not analog the H dac I heard was non discerning to me at axpona. I’ve never felt or heard a direct compare
like this Before
and the axpona room I felt had good vinyl to me.
Do you remember what tube complement was used in the H-DAC at Axpona?
dminches
3,453
2,838
1,410
dminches
3,453
2,838
1,410
Definitely KT170s and a TAK 274B. I don’t remember the drivers.
christoph
4,674
4,071
825
Golum
1,812
2,575
405
Lausanne, CH
dminches
3,453
2,838
1,410
Golum
1,812
2,575
405
Lausanne, CH
There is no cure.
That's a relief to know....then I'll just continue...would love to dig out some interesting Russian NOS pentode which could fit the purpose. Idea is to combine 5c3s recti with Melz and this pentode...so if you know for any whisper it pls
shadowlight
169
127
173
aren't 6p3s-e equivalent to 5881/6l6?
Golum
1,812
2,575
405
Lausanne, CH
Yup they are...might try those as apparently there is nothing else...would be cool to try these... 4628BCD5-4BE3-4ACA-8C34-0CCA7C1F704F.jpeg AB11D278-E4BC-495C-8580-4E3BE6470D58.jpeg 17929288-D6C8-413A-AFD6-2ED869406471.jpeg
LampiNA
348
864
335
Tuckia
474
732
180
Wow==bizarre tube. That looks like drug paraphernalia.
Doubtful. Way too clean inside. But with some modification and the right adapters....
Golum
1,812
2,575
405
Lausanne, CH
dminches
3,453
2,838
1,410
On to the VT-99s. So far they sound similar and as nice as the TS 6SN7.
Golum
1,812
2,575
405
Lausanne, CH
Reactions: Alrainbow
dminches
3,453
2,838
1,410
Reactions: Alrainbow and Golum
Golum
1,812
2,575
405
Lausanne, CH
Guys for all using small signal double triodes i could reccomend to try those things…does not harm but can help as I do believe it helps cooling the bulb itself quite significantly as the fins get extremely hot…
What rectifier and which triodes are you using. I find the Thomson CSA 5687 to sound best in my system. The Kt170 plus the Tak274B created by far the best dynamics
Reactions: christoph
