From the info that Vince posted. The DAC has a control link module that is included when you purchase the director. You just install it in your DAC and connect with the fiber cable to the director.How does the Director's Control Link's TOSLINK cable connect to the DAC? A visual schematic, please!
The Digital Director is designed to maximize the conversion potential of any current MSB DAC. It does this in three ways, by providing perfect digital isolation, offloading processing from the DAC itself, and re-clocking all incoming data regardless of the input format. It supports all of our Digital Input Modules. When you add the Digital Director the MSB DAC needs to be able to command the Digital Director to switch to the correct input, process the DATA correctly and send commands upstream to servers and other sources (volume, mute, play, pause, etc). The Digital Director comes with a "Toslink" cable based fiber control interface and a ProISL input module for audio data. The control interface is not actually Toslink but a packet based serial interface that uses Toslink cabling. It is only active when the DAC needs to command the Digital Director. These modules are both installed in the DAC. All of the DACs current input modules are removed and installed in the Digital Director. A single-mode glass fiber cable and a Toslink cable are then connected from the DAC to the Digital Director. Digital Audio and information that needs to be passed to the DAC streams over the ProISL interface. The "Toslink" Control interface is used infrequently such as when the DAC powers on and need to configure the Digital Directors processing parameters, when the input needs to change or when new volume info needs to be sent to an upstream server. The quality of this cabling is unimportant, any Toslink cable will do (plastic or glass is fine). We found it was very important for ultimate quality to have no wires (other than power and analog audio) run to the DAC at all. This was necessary to completely break the noise coupling paths from upstream products. We considered wire and hybrid fiber/wire interfaces but found there were always some circumstances where substantial noise could be coupled over the wire portion of the interface depending upon upstream conditions. Even with the ProUSB there are substantial improvements in quality because of the offloaded processing and substantially better power provided to the ProISL transmitter in the Digital Director.How does the Director's Control Link's TOSLINK cable connect to the DAC? A visual schematic, please
Thank you for the very helpful insights, especially in the context of the existing ProUSB. Can you elaborate a bit on:The Digital Director is designed to maximize the conversion potential of any current MSB DAC. It does this in three ways, by providing perfect digital isolation, offloading processing from the DAC itself, and re-clocking all incoming data regardless of the input format. It supports all of our Digital Input Modules. When you add the Digital Director the MSB DAC needs to be able to command the Digital Director to switch to the correct input, process the DATA correctly and send commands upstream to servers and other sources (volume, mute, play, pause, etc). The Digital Director comes with a "Toslink" cable based fiber control interface and a ProISL input module for audio data. The control interface is not actually Toslink but a packet based serial interface that uses Toslink cabling. It is only active when the DAC needs to command the Digital Director. These modules are both installed in the DAC. All of the DACs current input modules are removed and installed in the Digital Director. A single-mode glass fiber cable and a Toslink cable are then connected from the DAC to the Digital Director. Digital Audio and information that needs to be passed to the DAC streams over the ProISL interface. The "Toslink" Control interface is used infrequently such as when the DAC powers on and need to configure the Digital Directors processing parameters, when the input needs to change or when new volume info needs to be sent to an upstream server. The quality of this cabling is unimportant, any Toslink cable will do (plastic or glass is fine). We found it was very important for ultimate quality to have no wires (other than power and analog audio) run to the DAC at all. This was necessary to completely break the noise coupling paths from upstream products. We considered wire and hybrid fiber/wire interfaces but found there were always some circumstances where substantial noise could be coupled over the wire portion of the interface depending upon upstream conditions. Even with the ProUSB there are substantial improvements in quality because of the offloaded processing and substantially better power provided to the ProISL transmitter in the Digital Director.
Right now some input data such as the data from S/PDIF inputs come into the DAC not synchronous to the DACs clock. They are buffered in the onboard memory in the DAC and then played back from local storage. The Digital Director takes over this task and sends all data to the DAC synchronously using the DACs onboard Femto Clock which is transmited on a dedicated fiber from the DAC to the Digital Director. Other ProISL sources such as our Transport and ProUSB do this already but the Digital Director does this for all sources.Thank you for the very helpful insights, especially in the context of the existing ProUSB. Can you elaborate a bit on:
1. What improvements the added processing power has brought to the digital filters and how that translates into sonic performance?
2. When you say the DD reclocks all incoming signal, does it leverage the Femto clock inside the existing dac, or does it have its own clock in the new chassis?
When will you announce prices for the directors?Right now some input data such as the data from S/PDIF inputs come into the DAC not synchronous to the DACs clock. They are buffered in the onboard memory in the DAC and then played back from local storage. The Digital Director takes over this task and sends all data to the DAC synchronously using the DACs onboard Femto Clock which is transmited on a dedicated fiber from the DAC to the Digital Director. Other ProISL sources such as our Transport and ProUSB do this already but the Digital Director does this for all sources.
From another forum…When will you announce prices for the directors?
Thanks for the info. All I can say is . I guess this is the price to play with the big dogs. And yes I want oneFrom another forum…
The Select Digital Director > $27,500
The Reference Digital Director > $24,500
The Premier Digital Director > $14,500
That's the price of a whole new Premier DAC, or a Taiko extreme server, the improvement must be mind blowingFrom another forum…
If the Digital Director upgrade elevates ALL digital input sources (including the Network Renderer V2) to the level of MSB's Pro-USB/Pro-ISL combination AND improves on the already stellar sonic performance of the company's DACs (without increasing the gear footprint for those who stack the chassis) then that is quite an achievement. Is that hypothetical gain worth a good portion of an ultra-high end music server's asking price? Only the end user can say.That's the price of a whole new Premier DAC, or a Taiko extreme server, the improvement must be mind blowing
When someone is using USB only as input is there an advantage in SQ using the Director in comparison to ProUSB?Other ProISL sources such as our Transport and ProUSB do this already but the Digital Director does this for all sources.
I expect the Digital Director to improve on all fronts. Now obviously I need to listen to one to know for sure. But I don't expect the Digital Director to make the Network Renderer V2 sound similar to a high-end server. Now this is just me as I believe a system is only as good as the source. I would expect a server utilizing a ProISL/ProUSB going into a Digital Director to sound better than the Network Renderer V2 into the same Digital Director. But who knows????If the first two are fully taken care of by the introduction of the Digital Director, why would the sound not be VERY similar between the MSB Network Renderer V2 and a Taiko Extreme (as an example)?
...why would the sound not be VERY similar between the MSB Network Renderer V2 and a Taiko Extreme (as an example)?
So we have roughly the same price for:
1.) Select Digital Director with MSB Renderer V2
2.) Taiko Extreme with MSB ProUSB
both into the same MSB DAC. I would be VERY surprised if 1.) is superior or even on par.
Matt
Exactly,These questions are all hypothetical and the final proof is in the listening
Are you interested in a ProUSB into the Director with a Taiko/Aurender/etc?Exactly,
hopefully MSB will offer at HE Munich comparisons between with and without Director and hopefully they answer my question if Director offers a superior SQ than ProUSB for USB only sources
Matt
